The X100 clearly exhibits artifacts when point light sources are extremely over exposed. I use the word extremely with purpose because there are many samples where over-exposed point-light sources do not exhibit these sort of artifacts. I think the artifacts come multiple problems with the optics and sensor electronics.
Some people complain this is a dynamic range short coming. I think it is more likely an exposure error problem created by inadequate X100 "multi" meter firmware.
Until my camera arrives, my hypothesis is the X100 is more prone to over exposure artifacts than most APS-C cameras. I shoot interiors for a living. When I'm not careful it is easy to severely over expose point-light sources. I know my D300 with both the 12-24/4 Nikkor and the 11-16/2.8 Tokina can display artifacts that look similar to the X100 examples. The D700 with the Nikkor 17-25/2.8 behaves much better in these situations.
My plan for dealing with this issue is to underexpose compared to the X100 "multi" recommendation, or use the spot meter near (but not on) the point light source. The goal is to keep the over exposure within the limits of the camera. I'm counting on pulling up the shadows and midtones in RAW file. This works well on the D300/700 and only time will tell if the X100 RAW files behave the same way. If the shadows can not be pulled up, then those who blame the X100's dynamic range for the artifacts, and for a tendency to over expose in general, will be correct.
