raid
Dad Photographer
Thanks. He was a physicist and he had created many things in his life. I used to show my students the German 10DM note which was dedicated to his inventions.
Can you say a bit about why no Voigtlander rangefinder lens shows up on these lists?
The 40 I already had, Jamie. I just added Voigtlander Color Skopar, and the 1.5 and 1.1 Noktons. Even though the 1.5 is an aspherical, it can still be considered a back-extended Ultron, similar to 1.1 Nokton and Color Skopar. And the 50/2 and 3.5 Heliars didn't fit in my simplified concept (there are other 50mm lenses with more complicated double Gauss derivations). Attached the diagram of the aspherical Nokton.
Thanks for doing this! Somebody make this a sticky, immediately!
Carl Friedrich Gauss was also a big mathematician, Raid. What few people realize is that he lived in the same time period as Augustin-Louis Cauchy and Évariste Galois, they knew and corresponded with each other, even while Galois was sitting in the Bastille. All three of them did huge contributions to field theory. An amazing time for science ...
Roland.
Brilliant! There are some links to original CZJ lens blueprints in my sticky thread in the Members Only sub forum. If you don't already have these, knock yourself out.
Cheers
Brett
Ultron Back Extension
The basic Ultron design was extended by adding an element to its back as first calculated by A.W. Tronnier in 1932. This design became very popular for fast 50mm lenses in the 70s. One of the most successful such design was patented by Glatzel and Behrens [EXTULTRON] and used for the Zeiss Planar 50mm f/1.4 lens, used among others for the Rolleiflex SL35 system.
The following is an incomplete list of classic normal lenses using a similar 7 elements in 5 groups configuration, where example pictures taken with the last five lenses can be found here.
- Zeiss Planar (C/Y) 50mm f/1.7
- Pentax (FA) 43mm f/1.9
- Pentax (A) 50mm f/1.2
- Canon (EF) 50mm f/1.4
- Yashica 50mm f/1.4 and 55mm f/1.2
- Porst 55mm f/1.2
- Zenitar 50mm f/1.4
- Voigtlander 50mm f/2.5 Color Skopar
- Voigtlander VM 50mm f/1.1
- Minolta AF 50mm f/1.4
- Olympus OM Zuiko 50mm f/1.4
- Olympus OM Zuiko 50mm f/1.2
[*] Pentax-M SMC 50mm f/1.4- Voigtlander 50mm f/1.5 ASPH (LTM and VM)
