Ororaro
You fixed it foyst.
You fixed it foyst.
There are also many formulae for do-it-yourself Xtol-like developers. Xtol really is amazing, but what is usually forgotten is that using ascorbate is only a third of its amazingness. The other qualities it relies on are weak alkalinity that is buffered so the pH rises and the activity is increased for the amount of developer with dilution. None of the vitamin-c-triethanolamine developers, for instance, have those qualities, and the grain is usually much more coarse and uneven as a result.
Have you ever used CatLabs 320, or Xtol?
I heard once a talk by Dick and Sylvia about how they created XTOL, it was very interesting as to why and how.There are also many formulae for do-it-yourself Xtol-like developers. Xtol really is amazing, but what is usually forgotten is that using ascorbate is only a third of its amazingness. The other qualities it relies on are weak alkalinity that is buffered so the pH rises and the activity is increased for the amount of developer with dilution. None of the vitamin-c-triethanolamine developers, for instance, have those qualities, and the grain is usually much more coarse and uneven as a result.
Ever, you ask?
Let’see. Yes, now I remember: during the years 2020, 2021 and 2022, I have printed north of 55-thousand prints. Roughly the same ballpark through 2010 to 2020.
One thing that is clear to me, and I can assert this expertly, believe me, is that XTOL is not a good developer.
In short, it kills tri-x to a bland, lifeless negative.
I wonmt go on with the long version because all this will result in is a loss of time and a lot of bickering, mainly from people that DO NOT KNOW but repeat what they read.
In super short, I will recommend two developers: D76 and Ilfosol-3.
Even shorter: what you think you like in XTOL, Ilfosol-3 will give it to you in Spades.
If anyone has done MORE
than me on this matter, I will listen.
And you? Any serious printing going on?
Xtol made a big splash when it came out, and article has the original formula "The Genesis of Xtol," by Dick Dickerson and Silvia Zawadski (Photo Techniques Magazine, Vol. 20, No. 5, 1999, p. 62 ff)
Great, maybe you should show us some of your photos. Your gallery is empty, and I can’t find any in your posts.
This thread is not about perceived quality of Xtol, or about printing. It is about film developer activity.
I run qa/qc for a commercial lab that still does black-and-white film. They process 20-30,000 rolls of film a year. Until 2019 it was all in Xtol. Now it is all in Adox X-T3.
Catlabs 320 in 120 format has no edge markings, and Xtol can suddenly lose activity to zero. It makes stating that the OP fixed first a hazardous assumption.
Marty
201101-10-M7-1600PR-135ELMARIT-35LUX25 copy by Gabor Samjeske, on FlickrThese a great - not too grey and flat😉View attachment 4832566
This one is on Neopan 1600 in Xtol 1+3. I miss that film.
I have had mishaps with Xtol, but it never cost me any shots because I check each batch. I used to mix it 50L at a time, but Kodak stopped supplying them. The lab I help out at doesn’t replenish, so they use a lot of Xtol/X-T3.
I’ve clearly been doing something wrong for decades.These a great - not too grey and flat😉
