chanzhf
Greetings to all seniors and experts here.
I will like to seek some advice regarding a Yashica Electro 35 GT that i have. Cosmetic wise, perfect. Function wise, a little issue.
Putting in a battery, the camera only functions in bulb mode be it the dial selector is at 'B' or 'AUTO'. To be more precise, the shutter will not close until i let go off the shutter release button. Along with that problem is that the 'Slow' arrow light always light up when the shutter release is depressed, regardless of lighting and apertures.
I did some intensive readings over at photo.net, classic camera repair forums, and yashica-guy. The common solution seem to be a POD or some adjustments at the rod at the base plate. Tried them both, fitted in a new rubber pad but i still dont see a difference before/after.
Now here is the problem. I wish to attempt to fix them myself and in the process learn more about vintage cameras.
I brought them to 2 local technicians to have a look to maybe seek some advice. The first one refuse to let me know what the problem is, but he claims he has encountered many of such similar issues is and said he'll repair it for quite a hefty amount, about US$150. The second technician diagnosed it as an electronic issue, and said he'll try to change the circuit board 'A' with his own parts. He quoted similar repair fees.
Hearing these, i would like to seek another opinion from the members here at rff. Are there any methods i can try out to rectify the so called permanent 'Bulb' mode and the permanent 'slow' arrow light? i have another yashica 35 gsn which has a broken lens and focus ring. If there were similar parts that i can salvage from there, please do kindly advise.
Thanks for your time and response.
