Yashica M3
ValProPh
12:51 PM
I would like to ask a question about one camera I can’t find anything about.
Yashica M3!? Anyone knows anything about it?
Will really appreciate your help.
Welcome to the forum.
The closest Yashica came to the Leica M3 was the Yashica YF from around 1959 which was really a re-badged Nicca, when Yashica bought them out for their focal plane shutter construction expertise a few months before. This was the sad end of the Nicca camera company.
The camera came with a very good Yashinon 50mm f 1.8 made by Tomioka
The YF was not a great seller, as by 1959 everyone wanted an SLR as the latest and the greatest. Many YF models were sold at a great discount in the early 1960s.
http://camera-wiki.org/wiki/Yashica_YF
If you cross reference the images of the M-3 and the Minister III, you can see they are the same camera. There is also a youtube video with an M-3 and I've owned a Minister III, so I can tell you they are the same. It is an uncommon, short production camera with a decent lens and a selenium meter.
Do you have one?
Phil Forrest
HC-110 problem
HC-110 problem
I've been using HC110 with dilution H for awhile with no problems. The last roll of Tmax 100 in 120 was a total failure. I went through the developing process and when the time was up I poured it out and it looked like ink. I thought to myself " that looks like the emulsion just washed out". I kept going through the process of "stop,fix etc." just incase things were still ok; but in the end, my film was clear. The emulsion was completely cleaned off. I noticed that when I poured it in my tank it looked amber colored instead of clear. Does HC-110 change with time? I mixed it one month ago. I processed a roll of 35mm three days earlier with no problems. I just dumped what I had left and mixed a new batch but haven't tried it yet.
Mike
Do you have one?
Phil Forrest
Thanks for information. Yes I have bought one, and it was very interesting to find that it was quite rare one...
Mike
Sorry, wrong thread will move it
The M3 was renamed as the Minister III because Yashica was sued by Leica over the name. And that wasn't good enough for Leica, as Minister III could still be contracted into M3, so Yashica then switched to letters for the designation with the Minister C even though it was a newer design (C being the third letter in the alphabet, but it was the fourth camera).
There never was an M2 because the M3 was the third camera made under the new designs, after the Yashica 35, and the original M.
PF
There was a Minister II.....
http://camera-wiki.org/wiki/Yashica_Minister_II
The Minister I (just called Yashica M on the camera) had a light value set shutter, and a long rewind crank on the base, which pops out when "rewind" is selected.
Also after the Yashica 35, came the YK, which looks similar to the 35, but with a shorter base rangefinder and f2.8 lens; and the YL, which has a stepped top, and parallax adjusted framelines.
