Abbazz
6x9 and be there!
Pherdinand said:Use film. 😛
Cosmic rays can also adversely affect film. And there is no way to protect the stock in your freezer against those radiations (see this thread).
Abbazz
DavidH said:Most of the big pro tv cameras have an abillity to map out any affected pixels - an extended black balance identifies the pixels...Have no idea whether any digital stills camera has the same ability but I doubt it at the consumer end of the market at least.
Abbazz said:Cosmic rays can also adversely affect film. And there is no way to protect the stock in your freezer against those radiations (see this thread).
Abbazz
Sparrow said:Ya……. but what about neutrinos
And fast food at the same time.Sparrow said:Like a low mass diet?jlw said:They're pretty good with milk, sugar, and sliced bananas.
Ha! Very fast food indeed!rxmd said:And fast food at the same time.
Philipp
jamiewakeham said:Oh, dear... awful jokes! Am I not the only physicist on this board, then?
Jamie
jano said:Wouldn't the ray affect the sensor only if it were on/powered?
Ben Z said:Well this is just ducky. $5000 for a camera and every time you take it on a trip some pixels get killed off. I wonder how many pixels will already be dead by the time the M8s are flown from Solms to distributors around the world, then flown to the dealers, then flown to the customer. Send it back under Passport you say? Great, since Solms will be the only place that can fix it at least to start, that's a 9 hour plane ride back to NJ and a 3 hour plane ride to Chicago, so it's like Sysyphus pushing the rock uphill :bang: Seems like a good reason to stick with $800 one-generation-past Canon refurbs.
There is, however, a peculiar neutrino shielding property of ordinary brown paper if wrapped around a Leica M8. This property is mediated by affixing an antineutrino catalyst seal to the outside of the paper and coding it with a set of codes. The sealed camera must then be put in a protective box.Sparrow said:I wouldn’t worry about it one or two layers of aluminium foil offers the same protection from neutrinos as 1/4" lead shielding.
