rlouzan
The chart is just way too small to fill the frame at 1m, but at 0,75/0,50 cm ... that's another story. Try it and see!
I don't get it either.
The chart is just way too small to fill the frame at 1m.
Hi, in my experience almost 80% of the lens i´ve owned had some focusing issues.
Some of them were brand new:
Rollei sonnar hft 40/2.8 back focus about 3 inches
Biogon 35/f2 back focus about 2 inches
Biogon 28/2.8 front focus 1 inch
Elmar 3.5 cm front focus 4 inches
Jupiter 12
Canon 35mm f1.8
Jupiter 8, front focus can´t recall amount...
Not to mention fast lenses like the canon 50/1.2 but that´s another story.
I don´t think seller even know they´re off focus , so early i decided to fix the problem myself, because here, are no technicians that can help me.
RF can be also troublesome i calibrate them at night using red lights on antennas set about 2.5 miles away from home.
even at that distance setting infinty can be hazardous, a slight difference may mean some shifting at 1 metre.
I can make these jobs because of a digital RF camera, with film is virtually impossible to remember any bad setting or miss alignment on the lens or on the RF of your cam.
And you must take into consideration that people never have the same eyesight capabilities...
So i wouldn´t be too annoyed cos it will happen again in the future, try to get some refund to set it to proper focus or best is to know how to fix the problem.
Bye!
... the lens has wobble and focus ring play, ...
Roland showed me the spanner ring and it's tight. Very tight.
these two statements contradict:
if the spanner ring is tight, there is no wobble.
if there is wobble, the spanner ring is not tight.
concerning focus ring play: the zeiss lenses i know have no noticeable play in direction of the optical axis. only one lens (the oldes and most worn one) has a little bit of play in the perpendicular direction of the optical axis - nothing interfering with the focussing of the lens.
maybe your lens is not collimated exactly?
cheers,
s.
Digital rangefinders are particularly picky about focus calibration, given the high resolution capability and mechanical nature of RF focusing. It's been my experience with two M8 bodies and one M9 that the bodies are in spec, while it's the lenses that need adjustment. Most M (and of course previous LTM) lenses were made with the expectation of use on film bodies where things aren't quite as critical.
One hopes lenses designed and made since the advent of the DRF have been kept to tighter tolerances. I've sent about a dozen lenses to DAG for 6-bit coding and/or focus check/calibration. All but two lenses needed adjustment, though for the focus-shifting C-Sonnar and 35 Summilux ASPH it was mostly a matter of optimizing at what aperture the focus should be exact. As I recall the 50 Planar-ZM needed no adjustment, and no adjustment could be made with the 1.4/35 Nokton, but others including 18mm Distagon, 21 C-Biogon, 25 Biogon, and both 35mm ZM lenses did, as did Leica 21 ASPH, 28 & 35 Summicrons. DAG just brings the lenses into correct specification on his test bench after having the coding done; I've not sent him a body to calibrate a lens to.
FWIW, SLR cameras are at least as troubled by focus shift as RFs, since generally focus is through the wide-open lens, whereas the actual shot is at a smaller aperture. If the lens has no focus shift and is simply out of spec, this shouldn't trouble TTL focusing... though AF issues are troublesome enough that some dSLRs now allow tweaking the AF settings for particular lenses.
There's really no getting away from it, IMO, without thorough checking and possible adjustments to spec.
Wouldn't rangefinder patch be out of alignment at infinity if the lens was not collimated correctly? I thought this is the way to check for this and I already stated that the patch is perfectly aligned at infinity. What else needs to be checked? I won't be able to check for it now as I have the lens packaged and ready for shipment to Zeiss, but I would still like to know...
Hm... How tight is tight? First I tried to unscrew the ring (with not much force). The ring wouldn't move. Then I tired to tighten it with a bit more power. Wouldn't budge at all. Now, I was relatively gentle as I didn't know if for tightening the spanner ring you need to fixate the ring underneath it first so that the force doesn't get distributed to some other parts of the lens...
Btw, Roland in his PM to me said that the other possible cause for the wobble are loosened screws inside the lens.
As for the focus ring play, mine is the same as yours. Annoying yes, but it doesn't seem to affect focusing.
So... A lens developed wobble and front-focusing while in the mail? Curious.
Yeah, I guess so. I did my homework though and knew some Zeiss lenses wobble. Buying a 'perfect' used lens vs. new seemed like a good idea at that time (even though it wasn't that much cheaper than a new one). I even liked the fact that it had some paint loss as that indicated that it was frequently used yet still perfect in mechanics and optics.Wobble, maybe not...but front focus maybe no? Wobble is a way of life with the Zeiss stuff...
Thanks for clarification on that. I thought that collimation of the lens only referred to making sure the lens would push the body rangefinder cam into correct position.collimation is the process to set the optical block into the correct distance to the basis plane of the focusing block. usually, this is done by adding or removing thin shims (flat rings of defined thickness).
your lens seems to need collimation. if i was you, i'd send it to zeiss.
regards,
s.
Where did I say those two things are connected?!A lens with wobble doesn't mean the focus is off. The two don't seem related, despite your instinct to think, "it must be!" Two totally different issues.
Just the once, over time. I'm speculating that the digital M is held to tighter tolerances than the film bodies... The specification is the same.Yes, I've read about Leica's film vs. digital body flange distance discrepancies. Did you had to have all your lenses adjusted when you moved between M8 #1, M8 #2 and M9?! Or just once when you went digital?
