Zorki 3m rewind
BILLC
1:39 PM
Amity, Oregon
I just ran two rolls through my 3m and when rewinding the second roll the rewind would not release. The first roll was fine but the second I had to depress the shutter for each frame as I wound the film back. On my other fsu cameras the coller around the shutter release is held down when rewinding but the 3m does
not move, is this normal? I have not used this camera much so I just don't know what to expect.
Bill
Hi Alan,
I set to B and the first roll wound off with no problem. The second roll started to and then stoped and I had to depress the shutter to disengage the sutter release. The shutter never fired, as the lever was at B. If I had known that it was not going to work the next time I would have looked to see how it was when it was working, now it is to late for that so I hope someone else has one that is working and can tell what to look for. Should the coller around the shutter release depress to diengage the shutter?
Bill
