john neal
fallor ergo sum
Dralowid said:A 90XXX serial number puts the camera around 1932. I think I remember reading that was around the time they moved away from the 11 o'clock position, so it might be the original lens.
Michael,
I have a II body with a 8xxxx serial, probably from the same batch. I too think this is 1932, and my 11 o'clock Elmar has a serial that is pre-1933. From my research, the Elmar did not have a serial prior to 1932, when numbering started at 80000. Mine is in the 120xxx range and pre-1933, according to Leica records.
1933 was about when the 7 o'clock became the standard infinity lock position.
