Help Film Counter Problem Retina IIa
metrix x
7:37 AM
I disassmbled the top of my retina IIa to lubicate the sticky range finder pivot point. I then reasembled being careful to follow the instructions for ressembling the frame counter from[FONT=Arial, Helvetica, sans-serif] Chris's camera pages[/FONT] . Now the frame counter will not count. Tryed dissassembly and reassembly a couple of more times but still no luck. I guess it is the ratchet spring but it looks just fine.
Does anyone know what actually goes wrong with the spring, does it hav a paw or something that breaks off, is it fixable?
Ryan
I've had a couple of these springs break. Micro Tools sells new ones at an exhorbitant cost so I bought a couple of 'parts' quality IIa's very cheaply to get a good spring. Then I sold the remains of the two donors so the spring cost me less than nothing. Check Micro Tools for a picture to compare your spring with:
https://www.micro-tools.com/store/SearchByCategory.aspx?CategoryCode=PAR
The Retina Ia uses the same spring, so a cheap example could make a good donor camera.
Its strange because my tab looks to be in good shape. I wonder if it is only slightly bent or something?
Thank you for the replys,
ryan
