squirrel$$$bandit
Massive dev chart has two entries.  One says 8 minutes, the other says 6.75.  Which one's right?
Thanks!
			Thanks!
ay caramba, I have a lot to learn...
This group would bitch if they were hanged with a new rope.
What is right is what is right for you. You are required to test.
For me, ISO 400 D76 1:1 for a condenser enlarger is 9.75 min. If I use stock solution time is 6.5.
Your water PH is different than mine. Your agitation is perhaps different. Your enlarger is more or less contrasty than mine. You camera and enlarging lenses are different.
You need to test.
Very true indeed...
I feel like an outsider with my numbers...
Tri-X or Neopan 400 gets D-76 1:1 @ 68* for 12 minutes, agitate for 15 seconds every two minutes...I like my negs and they print just fine with my enlarger...
You gotta find what works for YOU!!!
