mr_phillip
The CL's a great little rangefinder, no question, but if you're craving the Leica M experience then only a true M-series body will quench that thirst. Everyone's gonna express different preferences, but here's mine for what it's worth.
For the same money as a CL+40mm 'cron you could pick up a good M2 and a used Voigtländer 35mm Color-Skopar Classic. It's a combination I use daily and absolutely adore. The wee Voigtländer is one of the great used bargains in RF photography; mine cost less via eBay than I've spent in the past on a single bottle of the Macallan. I also own two 35mm Summicrons (a V3 and a V4), and the little CV runs them alarmingly close. If you find that the RF thing is for you, then you can upgrade or add more costly optics as you go.
Seeing as you're also in Scotland, you might want to check out Ffordes up near Inverness. You could take a day-trip north and have a good play with their stock to see what's right for you. They normally have a good supply of Leica Ms (and CLs), as well as new and used lenses.
