Spyderman
Maybe you should figure which focal lengths you want to use, and whether you want to expand the system (buy more macro accessories or such).
Research which system has the focal lengths you want and at what prices. What about bodies.
Then buy.
For example OM system: good bodies: single digit, most affordable OM-1, OM-2. Problems with rotting foam and damaged prisms - repairable by transplanting prism from OM-10. good lenses: most of them, especially the fast ones, but the cheaper slower ones are often just as good. Slower lenses share 49mm filters, fast 55mm. Lenses are usable on EOS with adapter, thus more expensive, but not nearly as expensive as Nikon F mount.
On the other hand Canon FD lenses are not compatible with any digital body (minus G1) and cheaper. Bodies: A1 (F1, T90 are more expensive).
Then buy.
