Short 50 mm lenses
degruyl
Just this guy, you know?
9:16 PM
Philadelphia
Are there any 50mm non-collapsible M or LTM lenses that are short? (I am thinking about pocketing, so the shorter the better).
I have a 50 mm Summicron collapsible, but I always feel nervous with it. I just purchased a rigid, but I was thinking about other options for use in carrying around.
consider this another vote for the cv 50 f2.5. the small aperture is made up for by having f22, which isn't always incredibly common in this day and age.
Another vote for the Voigtländer Color Skopar 50mm f/2.5, wich has however been discontinued.
Erik.
The Canon 50mm F1.5 is the shortest of the lenses that I own. It does not protrude into the finder of a Barnack Leica. On the bessa R2, you can leave a filter and Walz hood on it, and close the standard fitted case. It fits in the pouch case on the Leica CL, with filter and cap on it.
Hey Brian,
I haven't compared them side by side, but I would think the Nikkor 50/2 to be just as short. Can you confirm ?
Thanks,
Roland.
I popped the Nikkor-H 5cm F2 Black-Aperture ring off of the CL: the Canon is "ever so slightly shorter", but no practical difference.
Of course, my collapsible Nikkor 5cm f2 is shorter until extended.
Out of interest, what is it that makes you nervous? Is it that particular lens or is it collapsible lenses in general? I use the 50mm Elmar-M (new version) quite extensively and have never had any problems with it. It is very robust and makes for a very compact kit. The lens is superb and, in my opinion anyway, is currently the most under-valued m-mount Leica lens of any focal length. Some people are selling these for close to $500 these days. Just a thought.
Some people forget to extend the lens before using it. Happened to me ONE time. After that, no problem.
Oh, two issues:
1. Time to extend the lens, rather than just pop a cap off (I am careful, and it does take some time to do it properly)
2. At almost 50 years old, I get nervous with moving parts. Especially since torquing the tub will break a nice lens.
Note, I did not say that it was rational. The lens works beautifully, is only slightly hard to focus (I am not a tab person), and probably just needs to be lubricated. I just don't want to break it.
The utimate short is the 50 3.5 Elmar. The later coated versions are good and the best is Red Scale. Good luck finding one. 50 2.8 Elmars are like Summicrons.
Are there any 50mm non-collapsible M or LTM lenses that are short? (I am thinking about pocketing, so the shorter the better). (snip)
Are you thinking about pocketing the camera with the lens mounted on it, or pocketing just the lens?
I don't know about the former, but if it's the latter, a 50 cron is small enough that when walking around with 2 lenses without a camera bag, I always put one lens (either 28 or 50) in my pocket (jeans or pants). Lens in my left pocket and extra roll of film in my right pocket.
Bob
