ZorkiKat
ЗоркийК&
- Local time
- 5:14 AM
- Joined
- Jan 26, 2006
- Messages
- 2,070
I push Portra 160VC as a rule for my own work. One stop - it's exactly the look I want. I overexpose the negative by half a stop on top of that. For something like this, it's good to experiment for your own tastes because asking advice on forums has some limitations. But in short, yes, pushing and pulling does exist for color films.
But is the processing altered, or is it still standard?
You say that you "Push" Portra 160 VC. But then you add that you overexpose. When you plan to "push" (this happens in developing, not during exposure), you underexpose -and not overexpose- in the camera. The curtailed exposure is supposed to be compensated by extended (thus the "push") development.
However, when you intentionally overexpose, the corrective processing technique will call for reduced development, hence it's called a 'pull'.
A half-stop extra exposure with colour negative films, whose generous exposure latitudes will make serious overexposures still allow for acceptable negatives, does not really require any adjustment in processing.
A true push/pull application for colour film MUST involve some alteration in processing. Otherwise if the application just involves exposure alteration in the camera, it's just simply over or under exposure.
Colour negatives for the most part can't really be pushed by most labs because the typical processing machines (like the Noritsus) are designed to run at a fixed speed only. Sink-top processors or hand tanks may make C41 pushing possible, but usually this will adversely affect the dye densities in the negative.
Chrome films on the other hand do allow for pushing. That's because the first step, where corrective extended or attenuated development can be done, is in BW. Only silver densities form, and this determines how much is left in the film for subsequent colour dye development when the positive is formed.
...This is a set of photos I pushed one stop (160VC Portra) and shot rated at 200ASA:
VC 160 which is officially ISO 160 when pushed one stop should be rated at EI 320. 200 "ASA" is barely a 1/3 stop underexposure from the official 160. And that will hardly need a modification in processing - extended development- to make up for the rather slight underexposure.
