Canon 35mm F 2 and Filters
Mcary
8:54 AM
Virginia USA
Silly question time, But how do you mount filters on a Canon 35mm F 2 LTM, Do you just use a standard screw on filter, if so what size if not do I need to get some type of accessory and if so what size filter works with it?
Reason I'm asking I'd like to use this lens with my M8 which means putting and I/R cut off filter on it.
Thanks for any assistance
Mike
40mm screw in filter. This is on odd size, and you may be better off finding a step-up ring (e.g. 40mm to 43mm) and then buying the more common 43mm .
I bought a 40-40.5 step up from heavystar. Does the job nicely. Not sure if you can get a uv ir in that size as i got this lenses after i sold my m8
