35mm pre-ASPH Summilux Lens Hood Options?
The problem is however that this combination causes vignetting: black corners, see Maddoc's (otherwise very fine) pictures.
The 12585 classic Leica hood can also be used, it gives a better shade-off, but vignettes also, although less than the square Summicron 35 hood.
The best solution is to look for a chrome 35mm f/1.4 pre asph Summilux with the ollux (12522) shade.
Erik.
Paul, I have tried the hood for the 35mm Summicron-M pre-ASPH IV (last year, when I had one) and it did rotate on my Summilux-M so I gave up the idea at first. The hood for the ASPH 35mm Summicron-M fits much tighter and it doesn't rotate at all. Also additional friction is provided by the rubber o-ring filter combination. I glued mine into position that it fits very tight and needs some force to be mounted.
Thomas, in some photos I observe dark corners in some not. It depends a lot on the contrast, same as with my Noctilux.
Rich, thanks a lot for the photos and description of your setup. It looks like the most sophisticated and useful setup.
Spec, I use mainly a UVa filter for protection and sometimes a yellow filter for BW to increase contrast slightly.
You may want to proceed w/caution as Steve Gandy cites, the 35/1.4 "was recomputed in 1966 from # 2166702 onwards with noticeably improved performance." http://www.cameraquest.com/mlenses.htm
Simply not true. I own both, and there is difference between them, but every single Summilux 35mm f/1.4 pre asph seems to be different from all the others, so no recompution, only sample variation.
Erik.
Not so. It depends on whether one has seated the E39 filter so it is wedged against the outer area around the front element. The further out, the greater the risk of vignetting. Here's a sample image with this hood and there is no vignetting.
Okay, I am convinced!
Beautiful portrait, Thomas, very fine indeed.
Erik.
I bought the old style Leica Metal/Plastic Hood 'IR00A'
for my Collapsible Cron
and Guess what
it works on my 35 Lux
yes the Hood can turn
but NOT so wobbly like the 35 pre asph's original Hood
Its Quite Smart Looking
excuse this pix done on my crackberry ....
and Guess what
Good idea Helen! Are you sure there is no vignetting? The 12585 vented hood vignettes, but only a very little bit. Is there a lot of viewfinder cut-off?
Erik.
Erik.
Well I haven't finished the Roll Yet 😛
but will do it this weekend & develop it so the vignetting question will have to wait & see-
though I do think it will be ever so minimal or not at all.
The right bottom corner has abit of cutoff
but Does Not Diminish my Ability to Frame the Shot...😀
• Rear clip-on mount hacksawed off and a 42mm clamp-on mount (reasonably common on eBay) glued on with epoxy - doesn't take long to do, stops the rotation problem entirely, and allows better access to the aperture ring.
This is very interesting because the worst part of the rectangular hood on the 35/1.4 is the restricted access to the aperture ring tabs. I'm interested to know more details about the rear clip on mount you used and how much better is the access to the aperture ring.
It's a shame one of our enterprising Chinese aftermarket makers don't make a series of properly-designed rectangular hoods with clamps and caps for all these older lenses, they would sell a boatload of $50 hoods.
or better yet
or better yet
optimize hoods for rd1 and m8s which may allow for different sizes than full frame.
There are some advances, but not inexpensive, the Japan Exposures round vented hood has 2 filter mounts, a 40.5 and a 49 I think on the same hood.
Just my observation, I took some shots with my, new to me, summilux today using a 12524 rectangular hood. Shot at 2.8 on M9 I'm getting some vignetting. I also have a 12504 which came with the lens but I don't have a cap for it. Anyone know which cap I can use with the 12504? If I'm going to favour using the 12504 over the 12524 I'd prefer to keep a cap on it for protection when not in use.
As for stopping the hood spinning round I've also found white PTFE "plumbers tape" a good solution.
Nigel,
a E58 (58mm diameter snap-in cap) will work perfect. I bought a third-party OEM cap, tested with the hood an perfect !.
Gabor
