Harry S.
The V700 is a possibility too.
I used to have a canon scanner and hated scanning. I bought a V700 about 3 months ago after much deliberation now I love scanning! In turn its also made me excited again about shooting film.
Time saving with digital is a fallacy. I'm not saying it's worse or bad, but this notion that all you have to do is 'push a button' and you have a picture is ridiculous.
RobVinc, I do have smaller cameras..... MJU, XA, GR1v. My issue is not bringing the camera......... but the processing and scanning bit. Takes a good day to process and scan 4 - 6 rolls of film........ which I don't mind if i have time to spare.
Depends.
Processing and scanning film is a process that isn't part of a digital workflow, so it's going to require some amount of time that digital doesn't.
It takes me about 30 minutes to scan 6 frames. That's 3 hours for a roll of 36. Post processing takes a variable amount of time per image. My opinion is that it takes me more time to post process a scanned film image than it's digital equivalent. If nothing else, thanks to spotting and dust removal.
In contrast, I can load 36 images from a card and have my software do some basic automated adjustments on every file in about 30 seconds.
That said, the time involved in something we do for fun and enjoyment is less important than it is for a pro. But, if you don't have the time, you don't have the time. I'm surprised the OP has time to shoot, much less process and print.
[EDIT: Backup is not time consuming if you automate it. Or, even if you don't. I backup every hour, with no involvement on my part. A selective remote backup also happens on its own. And, every other day, I manually run a full backup to a separate RAID unit. I can automated that, but I've been lazy. Remember, too, the only way to backup a print is to make another one.]
davey, not sure if I can be considered experienced but I have done my fair share of processing and developing for the past 2 years.
Problem is I am scanning with a Plustek scanner which requires me to feed it frame by frame manually. Takes me about 40 mins for a 36exp roll of film
30 minutes for 6 frames!? Wow. I was upset about 40 minutes for 36 frames.
