Awesome, I'm going to try to go this route!!!
EDIT: I was thinking the Fuji X-Pro1 w/ 60mm Macro and the 52mm version of this product with a step down ring to 39mm... but it's not apparent if it'll work correctly.
I would want to see what you think is a good scan of slide and what is not.
John,
I have everything you need to copy slides one-to-one except the digital camera, and you can use my light table as a balanced light source.
I have a Nikon 55/2.8 Macro AIS, the required extension tube to go 1:1, the Nikon slide copier, and a nice light table for a balanced light source.
You can borrow this gear any time.
Cal
Some good tips guys - THANKS!
I'm going to try a 50/3.5 OMZuiko macro on the E-1
and see what I can do with it.
Rick
Perhaps I can borrow Tung's Canon 5d with Macro lens and your equipment and be done with it.
John,
Not sure if Tung's Macro lens can make 1:1 without an extension tube. The only lens I know that can do 1:1 without is the already mentioned Nikon 60 Macro AF. The Nikon slide copy attachment is 52mm filter size so I don't know if it will adapt to the Canon lens.
If you could use Jeff's D-700 or John Chee's D-700 everything would be very straight forward, especially with a balance light source (my light table).
Basically converting slides into digital files would cost nothing.
Cal
John, I think photovillage also have a Imacon , or something they rent...
Perhaps I can borrow Jeff's D700 and your equipment and be done with it.
John: I FINALLY scanned those slides you gave me way back when last night. Tonight when I get home I will quickly PP them (since I scan with all auto functions off) and I can email you the results in a couple zip files. Or, I can add them to a disc and mail it to you. Whatever you want. Anyway, I have a flatbed so it's not the best quality but I think they will be decent enough for the web or to be used to print up to 8x10.
For future scanning: If you can manage a day off and meet me at my job on day during the week, I can get you into a lab that had a Nikon Coolscan.
