I'm trying to fool my P&S. Help!
Vics
10:35 AM
California, USA
I really like my newly aquired Canon Sure Shot Supreme, but I'd like to shoot Tri-X at ISO 320. Does anyone know a trick for fooling this automatic camera? Thanks in advance.
I'm afraid most P&S cameras, at least ones not prohibitively expensive, don't read intermediate ISO values and either revert to ISO100 or closest lower value.
Suggestion to cut amount of light reaching sensor is good one, in days before I had adjustable camera I thought I could select several "filters" to trick AE brain but rather bought other camera.... Probably strip of not exposed and processed BW film would make variable density filter for this? I'll try this when I load some camera without control over exposure.
I don't know if you would need a filter, probably just a piece of black tape with a small hole cut in it to make a smaller iris for the sensor would work.
Count the number of DX contacts in the cassette chamber. If there's only four, which is normal, then give up as 4 contacts means 100, 200 and 400 ASA/ISO only.
Regards, David
This is a cassette re-coded by me to fool my camera into rating it at ei200. I call it the scrape and tape method. It is easy to use a modelling knife to carefully remove some segments and tape to make new ones. Two minute job, tops.
Good luck.
John.
Yes, let's imagine pouch with pre-cut pieces of film or bits of tape with holes of different sizes?
- what are you doing with this, is this new kind of school drugs?
- nope, this is to fool exposure meter!
Good luck.
John.
Thanks for that one, John. I'll give it a try on my next roll and post the results.
I have used real (metal foil) duct tape instead of scraping, and electrician's tape. The former is conductive enough and can be read by the contacts.
I also used it to gap seal my ducts!
Much cleaner and quicker than scraping.
I regularly upgrade Portra 400 to 800.
I found a tech pub on the Kodak site for Portra 400, but not one for Portra 800. Here are some questions that occurred to me. If you happen to be able to answer any of these, Aristophanes, I'd love to know. Thanks!
Are the 400 and 800 films the same emulsion, or is it just that 400 pushes easily to 800?
How does 400 pushed to 800 compare to the 800 film at 800?
You can push the 800 to 1600. How well does the 400 push to 1600?
I don't know too much about Portra 800. I do know that the 400 is "new" and supposedly based on their Vision 3 emulsions from their motion picture film stock categories. The current Potra 800 speed is an older formula. I would not be surprised if Kodak discontinued it and advised shooting Portra 400 pushed.
I shoot the Portra at 320, 400, 640, 800, or 1600 in an SLR or RF and move it around if I feel the need depending on the max. aperture of my lens. For a P&S with fast enough shutter speed I mark it at 800. I have a Fuji Natura Classica that has a no-flash, fast lens system and DX-only coding which is why I started marking the rolls.
I do NOT push in processing. It is always processed at 400 (box speed). I doubt I will print much above 5x7, so not a major factor in speed/grain measure.
I started doing this because of the work of Jonathan Canlas. You be the judge:
http://canlasphotography.blogspot.ca/2010/12/kodak-portra-400-miami-south-beach-fl.html
There are lots of other samples and related discussions on Flickr:
http://www.flickr.com/groups/portra400/discuss/72157627404027556/
For "beach" shooting or ISO 100 I revert to Ektar, a riotously fun film that I always shoot at 100. I have not shot the "new" Portra 160 (yet).
