swoop
I've owned my M9 since it was released. And owned an M8 for years before it as well. I've used both cameras for hundreds of assignments while working for magazines and newspapers and the occasional wedding. Not every gripe I have is a big deal, but they are all issues I've run into every so often that really limit or just annoy me.
-Max ISO of 2500.
Sometimes I just need a little more. 6400 would be ideal.
-That image quality is absolute crap beyond ISO 1600.
I really don't care all that much. But editors and clients do and I have to deal with the complaints when they notice all that grain/noise.
-The rear LCD is worse than what you'd find in a $200 P&S.
For $7k, it's really just one of those things you'd expect.
-That the sapphire glass wasn't made standard after the M8.2
If it was as awesome as they were trying to make it out to be they should have just included it.
-The small memory buffer makes the camera useless after 5 frames.
There are maybe a hand full of scenarios when I just really need to lay on the shutter and it's really frustrating when you see an awesome moment and the camera does nothing but blink.
-Using the lens profiles is needed for accurate color rendering of lenses.
They should just be right, there shouldn't be a need for special profiles to get accurate color.
-Using the lens profiles sometimes brightens up the corners of images causing the opposite of a vignette.
The fact that you need them for accurate color is one thing, but that they dodge the corners at small apertures making them brighter than the rest of the frame is really annoying. I'd rather have the vignette at f2, than have dodged edges at f5.6.
-That the batteries only last for about 300 frames and cost $130 each.
It's really a value thing. If I'm only going to get 300 frames out of it don't charge me fortune for the battery.
-That there's no self sensor cleaning when $1000 budget DSLR's offer it.
The sensor gets dirty quick and I hate cleaning it. If even cheap DSLR's offer sensor cleaning why can't Leica squeeze it in somehow.
-That the camera won't automatically add my name to the EXIF/IPTC of images.
This is a feature I was spoiled by on the 5D mk2. To automatically have my name added to the metadata is fantastic. It's one less thing to worry about, to know that I'll always be credited for an image, especially now that facebook reads and posts the metadata.
-That I need to use the Thumbs Up to hold the camera comfortable, but then can't use a flash on/off camera.
I love the Thumbs Up. It makes the camera feel so much more comfortable and secure to hold. But sometimes I need to use some flash, and I hate that I have to take the thumbs up off to do so. Sometimes I won't even bother lighting because of that.
-When the battery is low the camera becomes unreliable sometimes not even writing images to the card at all.
It's awful to take photos and never have them write to the SD card. And this only happens when the battery is low. Which is even worse because I don't even get the full use of the battery, I have to change it out when it gets to like 10% because I know when the battery is low the camera may as well say the battery is dead.
-That there's no live view, which I would only like for the sake of screen focusing with long (90mm/135mm) lenses.
I don't use long lenses often, and the only reason I even own a DSLR is to use long lenses. So it would be nice if I could use a 135mm lens on an M9 and use live view while zoomed in to focus because focusing a long lens on a rangefinder is a gamble.
-Max ISO of 2500.
