Jamie Pillers
Skeptic
Thanks. That's what I assumed. But sometimes my assumptions are wrong. BTW, I forgot Zeiss released the Distagon T* 25mm f/2.8 for ZE and ZF. So I'd probably select that one since I was originally hoping to use the Biogon 25mm f2.8 in the first place 🙂
Good to see you'll be able to use the Biogon. 🙂
By the way, I just did a quick look at flickr photos made with the x-pro1 and wide-angle M-mount lenses. I came across a photographer using the Voigtlander 15mm lens and, at flickr image sizes, they look GREAT! If there's any so-called smearing going on, it seems inconsequential to the final image.
