Godfrey
somewhat colored
I thought only the last generation of Coolscans used USB? I have the 4000 which uses Firewire, which is fine with me. It had a card in the box to put Firewire ports on my old computer. When I look at computers, I look for a Firewire port, they do not seem to be that uncommon. Some brands are more in to Firewire than others? Other than convenience, I have not heard that USB offers any great advantage, and it may well be the other way round?
Some of the Nikon strip feeders were very easily modified to feed entire rolls, details are on the web, so if you have an uncut roll, you can head off to lunch while the scanner does its thing and saves to the file you set up.
The Nikon Super Coolscan IV ED (LS-4000) is the "Super" model, which includes the FireWire 400 interface and a few additional features over the Coolscan IV ED. Apple computer systems have included FireWire ports on all models from the early 2000s to the past couple of years (now they're focusing on incorporating USB 3.0 and ThunderBolt). FireWire ports have been a bit scarcer on other manufacturers' systems.
From what Ed Hamrick (author of VueScan software) told me some years ago, the Nikon Coolscan IV and V scanners were amongst the very best units on the market from a build and reliability standpoint. I've certainly found both the Coolscan IV and V to be far more reliable and produce better results than the other three film scanners I've owned.
Both my Coolscan IV ED (LS-40)
http://www.imaging-resource.com/SCAN/CSIV/C4A.HTM http://imaging.nikon.com/lineup/scanner/coolscan_4/spec.htm
and Coolscan V ED (LS-50)
http://www.nikonusa.com/en/Nikon-Products/Product-Archive/Film-Scanners/9239/COOLSCAN-V-ED.html
http://reviews.cnet.com/scanners/nikon-coolscan-v-ls/4507-3136_7-30756222.html
are equipped with USB ports only. The LS-40 has USB 1.1 and the LS-50 has USB 2.0, but there seems to be no difference in actual scanning speed. (I suspect that even USB 1.1 can deliver far more data per second than any of these scanners collect ...)
The modification to do entire rolls with the strip feeder can ONLY be done with the Super Coolscan models. The Coolscan models do not have a through-port to allow the film to extend beyond the scanner body. Nikon made long-rolls scanning feeders for the Super Coolscan models too, but they were frightfully expensive.
VueScan is the most versatile scanning application I've found, and is extremely well maintained. It runs on Linux, Windows and OS X, and supports tons and tons of scanners and digital cameras (it does raw conversion too). It's a bit twisty to learn and has a complicated user interface, but it has worked brilliantly for me since I adopted using it in 1999 or so, when the Minolta software for the Scan Dual II was so bad I nearly returned the scanner. I make it policy now that I only buy a scanner if it is listed as supported by VueScan ... full information and a free evaluation download is available from http://www.hamrick.com
Note that I have no association with VueScan or Ed Hamrick other than as a very satisfied user. I bought the software with unlimited upgrades once upon a time, and he's been true to his word of keeping it updated and compatible with almost every version of every OS and scanner worth using.
G
