Vics
Thanks, PanF. It doesn't seem to be available over here in the US. I guess the UK Amazon ships anywhere. I'll try. Great film.
			Jeez, I don't know. I know your video is different than ours. My son works in TV. I'll ask him.Hello Vic,
It needs a Pal region 2 DVD player.
Are they available in the U.S.?
Erm... No sane person would deny that you can get good pictures with just about anything, if you live with its limitations and indeed learn to exploit them. But equally, no sane person would deny that some lenses are sharper than others; have more contrast; less vignetting, better ergonomics...Dear Roger,
One has only to view the photographs of James Ravilious who used an uncoated 35mm f3.5 Elmar,on many occasions, on his M3 camera to record many superb photo's of a disappearing world to see that it is the skill, ideas,and perfect timing of photographer not the lens that makes the photographic masterpiece.
See:- www.jamesravilious.com and also http://www.beaford-arts.org.uk/index.php?id=5
The 2.8 Summaron is a wonderful lens of sublime quality, but it is NOT inexpensive...I would like a really small/inexpensive 35mm.
We do not disagree about most of this. But equally I'd say that if someone is asking for advice on how to do something, it?s often better to advise them on the easiest way, rather than the most difficult.Roger,
I know that there are more modern sharper lenses, with more contrast and with less vignetting and better ergonomics available but many photographers are tired of these ultra sharp, high contrast images that these modern lenses produce with modern film stock.
Many photographers are favouring more the results produced by the older coated and uncoated "classic" lenses which give a defined more rounded yet slightly unsharp detail with film and more pastel dreamy images when used with modern colour films.
You yourself now find the 9cm f2.2 Thambar, an uncoated Leitz pre-war lens , long neglected and maligned by photographers,and desired only by collectors, to now be a lens that you couldn't now part with because it can give results that are unobtainable with modern lenses.
These older uncoated lenses such as the 5cm f2.5 Hektor (see the photo's by Erik van Straten & Tom A), 3,5 cm Elmar, 7,3cm Hektor, 5cm Summar and your 9cm Thambar are very capable lenses and ideal to use with current more high contrast film stock and shouldn't be discounted in favour of modern lenses.
I admit they are more of a challenge in use but many photgraphers enjoy a challenge and find great satisfaction in using a 70 year old optic and producing results with modern camera technology and film stock which would have astounded their grandfathers.
Lack of choice? If it's all that's available, what's the point of whingeing? It was taken for granted that it was soft and lacking in contrast. What could anyone do about it?It's interesting that until the Summaron came along in 1946 the Elmar was the only 3.5cm lens available for the Leica. Many memorable photographs, including much of the coverage of World War Two both in Europe and the Far East, were taken with it by photographers from all sides. We (nearly) all acknowledge that the Elmar 5cm is a classic lens so if the results from the 3.5cm were so comparatively disappointing why did it not get a worse press at the time? I wonder if like the Summar time has taken its toll of most of the examples we see. I have recently got mine back from Malcolm Taylor and I am looking forward to using it, though with slight trepidation as the front element came unscrewed when I removed a filter and I am not sure I have sufficientlky re-tightened it. I will report back but generally I have been getting great results with pre-war Leica glass.
Also, of course, 'reviews' of the period were often even more lickspittle than today.
I believe there is the fiddly 35mm f3.5 Elmar. Any samples of this lens-wide open or at f5.6? .
	They could go out and produce great photographs with it as thousands of 1930's/40's photographers did and particularly when it was in the hands of a great photographer like Dr. Paul Wolff.
