Voigtlander Heliar Classic 50mm f1.5
I can’t begin to achieve the results that Erik has shown with his film images and this lens. But folks interested in this lens may want to know what it’s like on a digital camera. The following posts are with the Voigtlander Heliar Classic 50mm f1.5 on a Leica M-E Type 240. I have not made any adjustments to the images so… no post processing, even when I did not nail the exposure. These are not particularly “good” photos, but I think they show some aspects of this lens on a digital sensor…
Starting off with one of my favorite subject, my granddaughter…
at f1.5:
Heliar Classic Test Shots by Steve Macfarlane, on Flickr
at f2.0:
at f2.8:
In my opinion, f2.8 may be a sweet spot for close-up portraits…
Some landscape-type photos, taken at Waterfront Park in Martinez, CA, next to the Carquinez Strait….
1/4000 at f4.0:
Voigtlander Heliar Classic test shots by Steve Macfarlane, on Flickr
1/500 at f.11:
1/500 at f5.6:
Notice that the background in the last photo is slightly out of focus… I’m seeing that this lens has a shallower depth of focus than I usually associate with 50mm lenses…
gelatin silver print (heliar classic 50mm f1.5) leica mp
Erik.
Thank you for posting your fine looking images here, Steve.
Have you by any chance used a Heliar 50/2 CV? I wonder if the Heliar 50/1.5 is "very different" or not.
Thanks, Erik! I will post three more shots from yesterday, taken on the M-E 240:
At around f2.0. The bokeh balls in the upper left are lights from a Christmas tree. The rest of the bokeh looks smooth to me.
Remarkable that the bokeh-balls in this shot - lovely little girl - are smooth with the lens stopped down. Usually bokeh-balls reflect the form of the exit pupil.
Erik.
Is then the bokeh the main difference between Heliar 50/2 and 50/1.5, other than the max apertute?
Thank you, Raid! I have not used the CV Heliar 50mm f2.0 lens, so I can’t comment on how it compares with the Heliar Classic 50mm f1.5.
Is then the bokeh the main difference between Heliar 50/2 and 50/1.5, other than the max aperture?
Both lenses, f/2 and f/1.5, have ten slats, quite a lot for a modern lens. The original Hektor 73mm f/1.9 (same design as the Heliar Classic 50mm f/1.5) has 15 slats. I will make some tests to see how my Heliar f/1.5 behaves stopped down. The diaphragm of the Hektor 73mm f/1.9 gives a perfect circle in every position. Heliars made by Leitz were called "Hektor".
Btw. the Hektor 73mm f/1.9 was made from 1932 and was used mainly by professional photographers to make passport photos of citizens who needed from 1933 a new "Ausweis" (passport). That is the reason these lenses are not really rare.
Erik.
The Hektor 135/4 is dirt cheap. Why? It is a Heliar design. Right?
Yes, it is, it is a triplet, but the middle element is a doublet (two elements glued together); that is why it is a Heliar. There was also an Elmar 135/4, that lens has a doublet rear element, just like the Elmar 50mm f/3.5.
The price has nothing to do with the type of lens. The price only reflects what a collector is prepared to pay for it.
Erik.
The 135mm lens is too long in RF for most users. The lens is built very well, though.
In the 1930's 135mm lenses were used mainly on large format cameras. 35mm cameras were practically unknown. The first 135mm lenses for the Leica were in fact large-format lenses mounted in mounts to fit the Leica. It was only much later that Leitz themselves designed 135mm lenses for the Leica.
Erik.
