raid
Dad Photographer
Of course you do not need it, but you "need" it.... I'll be doing a comparison.
I am looking forward to your comparison. I wonder how the 50/1.2 differs from the CV 50/2 APO when used at 2.0 and smaller apertures.
Lots of Spherical Aberration, Lots of Coma, and Chromatic Aberration. That's what you get when stretching a Sonnar design the F1.1. Crazy thing to do, but somebody had to do it and must love Sonnars as much as I do and have the resources to implement it! This is a Zunow 5cm F1.1 v2, which sold for the same amount of money over 60 years ago!
I've not done a direct comparison between the two, the 50/1.2 Nokton and APO-Lanthar. I did a few test shots on the M9 with the APO-Lanthar when some on another forum complained about "CA" on the M9. It was UV contamination that gets through the sensor, I showed this using a filter and a UV lamp. After that- on to the M Monochrom.
I just had to look up the Zunow. It will be interesting to see how the new VM Nokton is going to fit in with some of these legacy lenses or rather lenses based on legacy designs...
https://tahusa.co/lens-review/zunow-teikoku-kogaku-japan-50mm/
And...
https://imaging.nikon.com/history/story/0007/index.htm
The OOF is fine here. It was also at 1.1.
I used the APO CV with hundreds of images on my M10, and nobody commented on CA then. Could it be that CA is seen less on the M10 than on the M9 for some reason?
Leica M8 with Voigtlander Nokton 50mm f/1.1 @ f/1.4 by Jeri Leibovits, on Flickr"legendary Brian Sweeney" ... I'm still alive! I really should have put some marks on the inside of the lens after working on them. I've seen the Sonnar conversion pop up as "Is this a fake" and recognize the serial number.
1957- same year as me. ZOMZ was hitting stride in 1957. I have a very early ZOMZ 1956 that took a lot of work, but is quite good. There is one 1958 ZOMZ that I sold- and regret it! was one of the first few I bought to take apart, worked on it, sold it here. It had a different coating, I think for IR film. Never seen another one.
I use a 1.25x finder for the Jupiter-3 and most lenses faster than F2. It helps the hit ratio.
Attaches a photo I made with Voigtlander Nokton 50mm f/1.1 @ f/1.4
If you ask in to my opinion, then this is a great lens for my taste. And although I do not use it,
I do not see any personal need of mine, to upgrade to the new Nokton 50/1.0 lens. All I have
to do - and for that very reason this post was born - is to remind myself, to take out the
VC Nokton 50mm f/1.1 lens from the back of my closet, where I buried it ...
