boojum
Ignoble Miscreant
Just ran across this. I guess the price goes up as the size diminishes:
https://gizmodo.com/leica-announces-expensive-watches-1848499742
No red dot?????
It seems Leica is striving to ascend to the top of the conspicuous consumption heap.
It's been working out for them for quite some time now. It's my belief that had Leica not reinvented itself as a lifestyle brand, they would no longer be around today. This move would seemingly fit in well with that approach. While I have no interest in such things, if this helps keep them up and running then more power to them I suppose.
The engineering firm responsible for building the movement in both the L1 and L2 is Lehmann Präzision. Apart from having a wonderfully swish modern HQ on Weilerstraße in Hardt, they’ve done clever things with crowns on their own range of watches. Here they’ve played a blinder with the two Leicas. Not only did it specially develop two movements, one with a GMT function, it actually developed and produced most of the watches’ components in its Black Forest workshop. Properly vertical manufacturing.
The two 26 jewel movements are both manual-winders with around 60 hours of power reserve. The balance runs at a conventionally rapid 28,800Vph (4Hz if that’s your thing) and have a power reserve indicator.
And what movements they are! The bridges for the balance and the going train are separate halves of a grained and polished circle. The balance bridge is anchored at either end for better stability and has a novel micro adjuster. The winding train is almost completely open, again with grained and polished bridgework. Each screwhead is mirror-polished. The finishing throughout is, as you’d expect, very high quality work indeed. Fortunately, it’s not hidden away and Leica has thoughtfully provided a sapphire crystal, screw-on, caseback.
You can buy a Rolex for less, and it would be an automatic.
I'm wondering if the mechanical-only movements were also a conscious design decision in order to carry the mechanical camera metaphor foreword. Mechanical winds keep you in touch with (and creates a more intimate relationship with) a watch; more-so than an auto-wind movement - (akin to an auto-advance or auto-rewind mechanism on a camera).
I don't wear a watch. I tell time using Sunny 16. I feel freer and more creative.
