agricola
difficulty adding pic
Any suggestions for a sharp and small manual lens at 30-40 range, and not terribly expensive?
My nokton 35mm has too much character and looking for sth more sterile. I was planning for a fuji 35 f/2 but I would prefer a manual lens.
If it doesn't have to be fast, the 35mm f/3.5 Pentax Super Takumar is an excellent lens. You should be able to find one in great shape for less than $100. The Super Multi Coated and SMC versions cost a bit more, but are still a great value.
I think I am between the VM Ultron f/2 and the Fuji f/2.
The Ultron performs really well:
https://jacktaka.com/voigtlander-35mm-f2
https://keithwee.com/2022/01/25/review-of-the-voigtlander-35mm-f2-ultron-a-contender-to-the-leica-35mm-f2-summicron-asph/
Anyone has used the new Ultron 35mm f/2 on a Fuji?
Thanks AAlfano for the suggestion but I am looking for sth compact. So I guess the only adapted lenses that remain small are the Leica mount ones..
Anyone has used the new Ultron f/2 on a Fuji?
2021-06-09_201311D7K_5602 by Aaron Alfano, on FlickrThe 35mm f/3.5 Super Tak is about the same size as the f/2 VM Ultron and the f/2 Fujis, and weighs less than either (about 150 g).
Yeah but isn't the adaptor is as big as the lens? This is the SLR lens correct?
