Voigtlander 50mm f/1 Nokton Images Thread
the_jim
human
11:11 PM
Portland, OR
After a few months of patiently waiting, I was thrilled to receive my copy of the 50mm f/1 Nokton last week. I was excited to see how it would render on film when shot with a rangefinder. Most (if not all) the examples I've seen, up to this point, were all taken digitally.
The lens is well built...but it is just well built as most of my Voigtlander lenses (some of them have slightly better/worse fit-and-finish than others...but only if you're really nit-picky). It is large and heavy, but too much so that I don't mind having it permanently mounted to my camera. The focus throw and dampening are very nicely suited to precision focusing (to the best of my ability) an f/1 lens on a rangefinder.
I've had the chance to put a some rolls through my M5. I'll post some examples below (these are by no means exceptional images...just snaps from a guy excited about his new lens) and more as I develop/scan. If others want to add to the thread, go for it (open to any camera combo).
Jenny by Jim Fischer, on Flickr
Leica M5, Voigtlander 50mm f/1 Nokton, Kodak T-Max 400, Xtol 1:1 - Definitely shows a bit of the challenge of using the lens...focus is slightly off.
Leica M5, Voigtlander 50mm f/1 Nokton, Kodak T-Max 400, Xtol 1:1 - Nailed the focus here. The lens is the right amount of sharp.
Selfie by Jim Fischer, on Flickr
Wood Paneled Car by Jim Fischer, on Flickr
Tim Knight of Guitar Castle by Jim Fischer, on Flickr
Leica M5, Voigtlander 50mm f/1 Nokton VM, Kodak Ektar 100.
Perrydale, OR by Jim Fischer, on Flickr
Great stuff as always, Jim! Looks like that new lens is a good match for the M5.
Oh, and just for reference, I believe this is the newest ultra fast 50mm f/1 from Voigtlander, released in January 2022. Yes, f/1.0, not f/1.1 or f/1.2. The Head Bartender has some more information here:
https://shop.cameraquest.com/voigtl...s/voigtlander-50mm-f/1.0-leica-m-nokton-asph/
More technical specs at the links below. 9 elements, 7 groups, with 12 diaphragm blades:
https://www.cosina.co.jp/voigtlander/vm-mount/nokton-50mm-f1-aspherical/
https://www.voigtlaender.de/lenses/vm/50-mm-11-nokton/?lang=en
https://leicarumors.com/2021/12/10/...-0-aspherical-vm-lens-for-leica-m-mount.aspx/
A bit confusing because of Voigtlander's naming convention, including other 50mm Nokton varieties and versions. For example, looks like Peter's image posted above is from a different, older 50mm f/1.1.
Thanks for clarifying. Indeed, I intended this thread to be of images from the new (released in January 2022) 50mm f/1 Nokton.
There are many things that are impressive about this lens. The bokeh is smooth, but not boringly smooth...it has character. There is almost zero geometric distortion.
Flare resistance is very good. Here with the sun in the frame:
Silvershot Vineyards by Jim Fischer, on Flickr
And here with the sun just outside the frame:
The supplied felt-lined bayonet hood is very nice...but I have not used it. If I were adapting to mirrorless, it would be excellent. But, on a rangefinder, the viewfinder blockage is too much (plus it doesn't fit over the variable ND I use). Thankfully, the lens is very resistant to flare, so the point is mostly moot.
It is contrasty, but not overly so. It handles harsh lighting well.
Dad by Jim Fischer, on Flickr
Even at intermediate distances, the ability to separate a subject from the background is tremendous:
That's all I've got for now. All two of my rangefinder cameras are off at their respective doctors. Hopefully others will share some images from this lens.
I have hundreds of images with the CV 50/1.0 (with digital Leica M10)
link; https://raid.smugmug.com/Leica-M10-CV-50mm-1/
Thank you Jim.
There are many pelicans around almost each day when we visit Joe Patti's Seafood Market in Pensacola.
My first time out with this lens - Shot No.2 (f1.0)
Second floor lobby, Hotel New Grand Yokohama​
Sony A7III, Voigtälnder 50mm f1.0 Nokton VM lens
Voigtländer VM-E Close Focus Adapter II
August, 2023 - Yokohama, Japan
Image is lower resolution than original​
My first time out with this lens - Shot No.3 (f2)
Streets of Yokohama​
My first time out with this lens - Shot No.4 (f2)
My first time out with this lens - Shot No.5 (f2)
