The LUG Gallery: photographs by Leica Users
raydm6
5:23 PM
In case you are not familiar or have never seen this gallery. Some nice imagery here:
I didn't even know LUG was still around. Was a frequent visitor, sometime contributor, back in the old days. Even had a few of my pictures published in their yearbooks.
Jim B.
How does one look at the images in a larger size? When I click on the thumbnail, it just takes to another page with more thumbnails?
It's a bit of a tricky interface. Some Items will have a "Size: xxx items" (xxx items total)" label indicating more items. Sort of like folder or directory structure.
For example, Peter Dzwig shows: "Size: 19 Items (572 Items total)" - meaning, there are 19 labeled 'directories' or themes for lack of a better definition and a total of 572 images in those directories. Just keep drilling down into a file the lacks the "Size:" indicator and you will be on the actual image icon where you can perform Exif and view Full Size actions (see examples below).
LUG Tips 3.png - Click image for larger version  Name:	LUG Tips 3.png Views:	0 Size:	51.5 KB ID:	4793170
So for example if you select his name, then Select his directory France, you will see there are 7 images there which you can open and enlarge per my instructions below. (the directory France will have a label with "Size: 7 items").
Hope you can see these images: the camera icon above the image opens an Exif pop-up window and the second icon will pop-open a full-size image window. Hope this helps.
Meh.
Slightly bit more above regular dross. Outskirts anyway. I'd rather back to RFF gallery.
