Retina IIa shutter cocking gear and rack
MarkWalberg
8:53 AM
I've taken the shutter/lens out of my Retina IIa to clean the lenses. (There is still a bit of haze in the two cemented pairs.)
I'm having trouble getting the shutter winding to work when I put the shutter back into the camera.
There is a shutter setting gear inside the housing that is marked X and M (for the flash sync lever position).
The outside rim of the shutter has a toothed cocking rack that fits against this shutter setting gear.
How does one find the right position of the shutter cocking rack relative to the shutter setting gear?
It has to be set right for the shutter to cock correctly. There are many choices of where to put the gear.
At some positions, the lever goes all the way but the shutter does not cock at all.
At the other end of the rack, the cocking lever cannot be pulled all the way, but the shutter does cock.
Clearly, somewhere in between is the right spot.
I have not been able to find it yet. I can get it set so that the shutter works on all speeds except 1/500.
What do I need to do to get it set so that all the speeds will work?
Thanks for any advice !
On this page Chris shows the correct position of the cocking rack for a Retina Ia:
https://retinarescue.com/retina1astripdown.html
Yes, Chris Sherlock's site is full of great info. A wonderful place.
However, those pages with the cocking rack of the Ia and IIIc are for a different part of the cocking mechanism, the part near the wind lever.
The part I'm talking about is the rack that meshes with the gear located on the front at the edge of the shutter under the housing marked X M.
If you look through Chris Sherlock's videos on youtube, you will find a number where he overhauls Retina shutters, and sets up that cocking rack.
