Guth
Appreciative User
When seeing the title of this thread, like KoNickon my first thought was the Minolta CLE as I too use the lens in question. But after reading the conversation that followed it seems the real question is how well would the Leica M3 work with M-Rokkor 40mm lens design with regards to framing. However, your comment above has raised a question in my mind.To be clear I was thinking forum members would compare using a M3 or M2/4.
I had a CL but due to its short base it’s not on my list.
Is it with practice more accurate or easier to imagine the 40 frame line outside the M2/4 50 frame or more accurate to use the entire finder of the M3?
In your case you've mentioned elimination of the CL due to its short base, which is even shorter than that of the CLE. I am assuming that your mention of a short base is a reference to the effective base length (EBL). My understanding is that along with the quality/sharpness of the rangefinder focusing patch itself, the EBL impacts focusing accuracy. When it comes to framing, how does the EBL impact things? Is it more a matter of viewfinders with smaller magnification ratios (and therefore shorter EBLs) simply being harder to work with in this regard rather than being tied directly to the EBL itself? Regardless, I hope that you end up finding the right camera for your needs. Good luck!
