I have two of them, one with the goggles No. 20606XX and the other plain No. 17772XX, I do not know the years of production. It is funny that I can screw the optics from their mounts so that I can use the early one in the goggles and the later one in the plain mount. No problems with focusing.
I think that they are optically not for 100% the same. The later one seems to be a tad sharper at full aperture. But they are both the most beautiful 35's for the M Leicas.
I also have the plastic lens cap (found separately) and a whole collection of OLLUX shades, there are many versions of those.
I've not seen the new one in the flesh. It would be nice if this new one was tested against the old ones.
Erik.
Very nice Erik. Love the diminishing size of the trees with distance.Jean-Marc, I have the W-Nikkor 35mm f1.8 for the Nikon S2 too!
gelatin silver print (w-nikkor 35mm f1.8) nikon s2
Amsterdam, 2000
Erik.
How are you mounting your 35/1.8 on the M10-P? According to this page Amedeo Lens Adapter Leica M Nikon Rangefinder the Amadeo adapter is not compatible...
There are some lens wizards who offer conversions. Skyllaney in Scotland go the 'brutal' route of implanting the optics into a single helicoid mount with an indexed cam. Others such as this Korean gentleman offer modifications where they re-house the rear optics into a slimmer fixture so that it clears the rf-cam in the Leica. I prefer this route because it is less invasive and reversible.How are you mounting your 35/1.8 on the M10-P? According to this page Amedeo Lens Adapter Leica M Nikon Rangefinder the Amadeo adapter is not compatible...
~S
Hello Erik,
I've had a couple of Steel Rim lenses in the past and regardless of age and haze etc, their sharpness do vary with some of the batches .
This might be due to the glass they used which may have changed over the 6 years of production and/or their manufacture. Some lenses might have been better centered as well.
Late batches 206 and 216 are known to be sharper. Maybe they used lanthanum like in some other lenses ...
Right now I have an ex goggled lens from the batch 173 which Chris Andreyo / Skyllaney has "rebuilt" and am very happy with it .
I rapidly played with a Steel Rim reissue lens and did not find the "charm" the original lens offers.
The 2005 W-Nikkor f1.8 Nikkor reissue matches the original lens much better imho.
Best, Jean-Marc.
I knew of the skyllaney mod, but not the other - it looks like it wouldn't work on the 2005 re-issue though.There are some lens wizards who offer conversions. Skyllaney in Scotland go the 'brutal' route of implanting the optics into a single helicoid mount with an indexed cam. Others such as this Korean gentleman offer modifications where they re-house the rear optics into a slimmer fixture so that it clears the rf-cam in the Leica. I prefer this route because it is less invasive and reversible.
W-Nikkor 3.5cm F1.8 Compatible S-mount for Nikon S & Leica M (Reversible).
니콘의 전설적인 명기 W-Nikkor 3.5cm F1.8를 아마데오 어댑터를 경유해 Leica M 바디에서 사용하기 위한 여정이 드디어 마무리 되었습니다. 명실상부 당대 최고의 대구경 35mm 렌즈로 자리매김 해왔던 W-Nikkor 3.5cm F1.8은 최신 소재였던 란탄 글라스의 채용으로 아름다운 보케와 전구간 안정적인 성능, 매우 뛰어난 수차보정능력으로 인기가 높아 LTM버젼의 경우 실사용 상태의 개체도 $4,000를 상회할 정도로 몸값이 올라 쉽사리 접할 수 없는 렌즈였습니다. 사실 제가 처음 레인지파인더카메라를 손에...sangin1122.tistory.com
Modified lenses can then be used with the Amedeo Adapter or similar products (e.g. Coiro Optics in Korea produces high quality adapters similar to Amedeo, but with 0.7m min focus distance.)
The 35/f1.8 W-Nikkor rear protruding element will not fit an original Amedeo adapter .
Yet these lenses have been successfully modified !
You may refer to this RFF thread:
W-Nikkor 3.5cm f/1.8 - vintage vs. 2005 reissue
Thanks Will. Nikon S cameras tend to do that, so I suspect one might just miraculously appear in your dry cabinet one day ;) The 50mm lens that Nikon included in the Nikon S3 Limited Edition kit is a reissue, just not the sonnar optical version first released in the early 1950s (and engraved in...rangefinderforum.com
Skyllaney's conversion - of both original and reissue lenses - allows to focus in the Leica direction , RF coupling from 0,7m onwards and a live view non coupled focussing distance down to 0,35m.
and facebook page
Skyllaney
Skyllaney. 862 likes · 25 talking about this. Skyllaney Opto-Mechanics specialises in service, repair, conversion and manufacture of manual focus lenses in the United Kingdom.www.facebook.com
Best, Jean-Marc.
