Can We End the Term "Japanese Summilux?"
I have about fifty different 5cm/50mm Sonnar type lenses. I don't like it when someone calls a Nikkor a "Copy". I have one 50/1.5 made from the front of a Canon 50/1.5 and rear triplet from a Nikkor 5cm F1.4. Spacing between the elements adjusted to be RF coupled across the focal range. It is one of kind.
  • Like
Reactions: das
You're right, xayra33, you said it first. See, we can agree on something!
Just remember to go out and takes photos every time you get the uncontrollable urge to post something SJWish force-fitted with something about photography or photo-gear as an excuse to wax lyrically about your Woke-ism. 😀
Hm. A Honda could be called a Japanese Volvo. 🙂
Not even close. Volvo is distinctive up the 850/S70/V70. Can we all agree that RF Canon and their lenses are simply excellent to superb in their own Individual, distinctive way. As Hondas are among the finest small/medium size cars made in their own unique ways!
  • Like
Reactions: das
A great lens at a modest cost.
Finding undamaged Canon lenses that use the high index of refraction/ low dispersion glass that made their designs possible is difficult. This applies to the 50/1.8 v2, 50/1.4, and 50/1.2.
The 50/1.2 is not quite as sharp as the 50/1.4, even stopped down to F1.4. At one time, sold for less than the 50/1.4. Cost about 1/8th of the 50/0.95.
Get one.
In my opinion, Canon's lens coatings for color photography during the 50s and early 60s were just ok. Definitely not the best. I had a hard time correcting color scans shot with the 1.4. On the other hand, the contemporary 2.8 Summaron renders colors better than any Canon RF lens of the era I have shot with.
I had the 3.5cm F2.8 Summaron and the Canon 35/2.8. I did not like the Summaron, sold it. Preferred the Canon. In the end- kept the Nikkor 3.5cm F2.5. All three lenses use the same basic optical formula.
Finding undamaged Canon lenses that use the high index of refraction/ low dispersion glass that made their designs possible is difficult. This applies to the 50/1.8 v2, 50/1.4, and 50/1.2....
If you are so inclined, Kanto Camera has partnered with a Japanese optical company to produce replacement elements for the Canon 50/1.2.
A few years ago, they used to offer the same for the 50/1.8, but I believe that service is no longer offered.
Jim B.
That's weird because I kept the 2.8 Summaron over the 2.5 Nikkor. I spent a whole weekend shooting them against each other on high rez full frame digital. The Summaron barely edged it out. The Summaron rendered color a bit better, could focus more closely, and had just slightly better corners. But it was also designed like 7 years later, so it was probably not a fair fight.
I can see that being cost-effective for the 50/1.2. The 50/1.8- Patience and $50 got me a perfect Black V2 50/1.8.
Patience and $400 got a perfect 50/1.2 and Canon V-T Deluxe. I had two tries before that, both later lenses.
Canon 50/1.4- perfect one now, and another several years ago. Picked up one with damaged glass for $50, was going to use for the focus mount. BUT- got some of the damage out, sold it.
I found the Nikkor every bit as sharp as the Summaron. Maybe the individual copies, maybe the Nikkor being a Late version had the formula revised during the production run.
The rendering of various lenses is different, and like/dislikes is personal. One is not better than the other, just one person will like a particular lens more than someone else.
The Summaron is lower contrast, had more veiling flare then the Nikkor.
