DownUnder
Nikon Nomad
Nikon in its great wisdom made grips with AA battery inserts. I have two for my F65s (= N65s), our (shared with my partner) D90, and my very own D700s and D800s. Unsure if the Zf I now lust after has a similar pack, but I hope so. Most useful they are.
Other brands may have done the same, tho' I've never seen such a thing for a Canon. And I've been into Nikons since 1970, so my vision is, shall we put it politely, somewhat narrow in this regard.
(This must be the 'shortest' post I've written so far, ha!)
Rayt
Nonplayer Character
Canon used 2CR5 which was a real pain to find especially when travelling.
JohnGellings
Anything modern using AAs?And that's why I prefer digital cameras that take AA's.
I´ve honestly never had an issue with this... I think I prefer having a few rectangle shaped batteries that I charge over and over. I guess if you aren't the type to be prepared, then it's no fun having a camera without a battery.
Coldkennels
Barnack-toting Brit.
The only modern thing I can think of that takes AAs is the audio recorder I use for work. I'm marginally confused by anything that doesn't use rechargeable batteries in the modern age, whether it's the removable-and-chargeable ones in cameras or built-in USB-chargeable ones in everything else.Anything modern using AAs?
JohnGellings
Oh, I meant modern digital cameras...The only modern thing I can think of that takes AAs is the audio recorder I use for work. I'm marginally confused by anything that doesn't use rechargeable batteries in the modern age, whether it's the removable-and-chargeable ones in cameras or built-in USB-chargeable ones in everything else.
raydm6
Another one of my Pet Peeves:
For sale items that are positioned/posed/placed on rocks, bricks, cement, and other rough surfaces. Why?
I shake my head and to be honest, I get turned off and won't even consider the item - even though it may have been carefully placed on the rough surface to avoid scratches.
KoNickon
Nick Merritt
On the other hand -- AAs are at least standardized, and you can get them pretty much anywhere. Rechargeable batteries are not standardized, as far as I'm aware, and how long would replacements be available? (AAs don't burst into flames, either....The only modern thing I can think of that takes AAs is the audio recorder I use for work. I'm marginally confused by anything that doesn't use rechargeable batteries in the modern age, whether it's the removable-and-chargeable ones in cameras or built-in USB-chargeable ones in everything else.
Coldkennels
No... they just leak and corrode everything!(AAs don't burst into flames, either....)
In all seriousness, while proprietary removable-to-recharge batteries (like camera batteries) aren't standardised, as far as I'm aware, internal ones are... to a degree. Replacing internal batteries with equivalents isn't too difficult if you know where to look for the parts.
There's even been some brave people in certain circles who are splitting apart proprietary rechargeable batteries to reuse the case and circuitry and just replace the cell. If you're determined enough, it's possible.
Retro-Grouch
Yeah, it's a way of life for us weird Rolleiflex 6x6 SLR owners. Worth the effort, as there's no alternative.There's even been some brave people in certain circles who are splitting apart proprietary rechargeable batteries to reuse the case and circuitry and just replace the cell. If you're determined enough, it's possible.
Phil_F_NM
Camera hacker
Improperly used apostrophes, usually seen attached to simple plural nouns. Example: Leica’s, camera’s, etc., when the word’s meaning is plural, not possessive.
The use of “at” when denoting location. Example: “Where are you at?” “Where is Billybob at?” “On what floor is the Department of Redundancy Department located at?”
Complete omission of the preposition. Example: “…when I’m done work.” This is especially prevalent in the greater Philadelphia region but may be infecting the rest of the country for all I know. I haven’t had the opportunity to go anywhere besides NYC since 2016.
Phil Forrest
Phil Forrest
KoNickon
Nick Merritt
And of course when you see on a mailbox (for example) "The Smith's." Unless that's where the blacksmith lives, it's incorrect.Improperly used apostrophes, usually seen attached to simple plural nouns. Example: Leica’s, camera’s, etc., when the word’s meaning is plural, not possessive.
Phil Forrest
JohnGellings
Hmmm, I always thought that was like saying the Smith´s House, but I guess that should be The Smiths´... unless it is one guy called Smith or as you said a ´SMITH lives there.And of course when you see on a mailbox (for example) "The Smith's." Unless that's where the blacksmith lives, it's incorrect.
KoNickon
Nick Merritt
No, it should be either "The Smiths" (Dad Smith, Mom Smith, Child Smith #1 and Child Smith #2 live here) or maybe "The Smiths'" (meaning, this is the Smiths' house).
JohnGellings
I'm ok with that... but I do think The Smiths´ works... I see your point though.
DownUnder
Nikon Nomad
Agree. Especially when the rock, brick, cement and/r other rough surfaces, is/are in better condition than the item on sale...
Retro-Grouch
The proper term is "minty".Agree. Especially when the rock, brick, cement and/r other rough surfaces, is/are in better condition than the item on sale...
DownUnder
Nikon Nomad
Phil Forrest
Yes. The Zeisses or Zeiss's Syndrome.
Is it apostrophiitis or apostrophobia?
raydm6
Zeiss bumps or Weltini weltsYes. The Zeisses or Zeiss's Syndrome.
Former RFF Member @Huss cracks me up
Welta Weltini
I just got my second Welta Weltini II. Well, okay, it's the first fully working one (the previous has a bent cocking lever that jams, and the RF coupler is uncoupled -- I can fix it, when I have time). The Weltini isn't a model everyone's heard of, like a Retina II, Leica 3, or Contax II --...
Disappointed_Horse
I am a lawyer and you would be stunned by how often I see this error in professional and legal writing. And I'm not referring just to emails—I see misplaced apostrophes in documents filed in court all the time.Improperly used apostrophes, usually seen attached to simple plural nouns. Example: Leica’s, camera’s, etc., when the word’s meaning is plural, not possessive.
Phil Forrest
JoeV
Thin Air, Bright Sun
Then there’s the New Yorker magazine style book (or is it the NYT?) such as James’s versus James’.
