F
former member
Guest
The front elements are very close in diameter, 0.02mm- close enough that I could at least fit them in each other's fixtures.
The rear triplet is different. The post-war rear triplet has a smaller diameter, and measured slightly longer- by 0.15mm or so. Hard to measure length- did not want to mar the surface on the post-war lens. I used a piece of lens cleaning paper to wrap each triplet and measure the thickest point by sliding through the digital calipers.
If I come across a wreck of a post-war Sonnar for cheap, I'll be more aggressive. As it was- had to use suction cups with lens cleaning fluid squirted to get enough force to take out the front element and rear triplet. Did not try to remove the middle group. The answer: I believe the post-war CZJ 5cm F1.5 Sonnar is a revised formula compared with the wartime lens. Kind of like "Manufacture Specifications may Change Without Notice".
