F
Similar to what Greg did, I bought a Z6 to use exclusively with my 1950's Nikkor S lenses.
Most of the lenses I'm using on the Z5 are Leitz 50s and 35s in M and adapted LTM mounts. The S mount Nikkor-S 50/1.4 is something new to try, and I'm liking it so far. I still need to buy a F to Z adapter for all the pre-AI Nikkors I have and love.
I have such an adapter that I no longer need. PM me your address if you want it. 🙂
Interesting. How does this work? What do you see when using it?Zf can track the focus point for manual lenses, there's a setting to enable that. I have played around with it and it works reasonably well.
It does subject tracking while using a manual lens, so the focus point moves along with the subject (e.g. the eye), which you can use to enlarge the image at that area and fine tune to focus. I used it when I was on a trip about 2-3 months ago, haven't had a chance to give it another go recently. So its a bit of an assist, short of auto-focusing the lens of course. Will have to redo it to remember some more details.Interesting. How does this work? What do you see when using it?
Another point that is worth knowing on the Z6. The little square that shows the focus point can move around on the screen to various points. You can program, in the menus, the button that controls this focus square to bring the square back to the center when the center of the button is pushed.
It took me a long time to figure out how to do this, but it made the close focus function markedly more useful.
Just been thinking outside the box, as it were. Would a DSLR, such as a Nikon 810, make focussing easier. If it and similar models have the green focus assist light in the middle it could be beneficial.
Any thought based on experience?
Ta
It's all very well assigning a focus point to follow, but accurate focus with any manual lens on a mirrorless camera still requires the lens to be opened up to it's maximum aperture (as what happens automatically with a typical SLR camera) for the focus point and focus peaking to work perfectly. Anything other than 'wide open' means the focus point will be displaying the DOF of a smaller aperture and there is no way to guess exactly where accurate focus is within that DOF in the viewfinder. So to focus on something critical it can't be done at f/8 but needs to be done at maybe f/2 or the widest aperture.This is accomplished as follows:
CUSTOM SETTINGS MENU
f Controls
2f Custom Control Assignment
[choose a button; I chose the 4-way controller center-press]
choose RESET Select center focus point
View attachment 4834576View attachment 4834575
All true in my experience. The ZM C-Sonnar is one of those lenses that is harder to focus wide open at f1.5 than at f2I've found that with most lenses I can focus satisfactorily with a good EVF (and with magnification) with lens openings down to about f/4 to f/5.6. It is also true that with a good EVF camera, it's quite easy to spin the aperture to wide open, focus, and then stop down to taking aperture for metering and framing with little in way of losses since the EVF will amp up the image brightness such that it remains easy to see what you're doing. This is where adapted lenses fall down on DSLRs because the viewfinder becomes too dim for useful framing and the metering range is compromised with a stopped down lens.
With some fast lenses (f/1.2 to f/1.8), contrast and resolution wide open is poor enough that one stop down enables easier critical focusing than with the wide open setting. This is rare but I've seen it on occasion.
By and large, all things taken together, using the native mount lenses on ANY camera is easier and less prone to focusing or metering issues than using adapted lenses. But it is fun to experiment with alternatives, and with mirrorless/EVF cameras it can be a quite successful experience most of the time.
G
