I think the EVF in the Panasonic S1R is the same as the SL2 and the highest Rez one on the market at the moment.
I tried out the S1R in the store and could barely tell the difference between its EVF and that of the Nikon Z7 . I think we're now at the point of diminishing returns.
Huss,
I don't know if the EVF is in fact the same in the S1R either, but I know that the EVF in the SL2 "crushes" the old VF'er on my SL, granted my SL is 5 years old.
It is said that the SL2 sensor is the same, but then it isn't because it has a thinner cover glass.
If one dislikes focus peaking and prefers optical focusing exploiting the zoom in the SL2 is really-really elegant.
I'm keeping my old SL as a backup and a second body for now. Leica pricing is crazy. A spare battery use to cost $250.00, but now with the Trump tariffs the cost is $275.00. It almost pays to keep my SL just to have the spare battery at this point.
How was the rear screen on the S1R? I'll look up the specs.
Also of note the SL2 kinda has the "A" Mode active even if you are using "M" (manual) exposure. When you depress the shutter release half way the EVF will jump in brightness or become dimmer if there is a "Delta" (difference between) "A" and "M" exposure mode settings.
This initially was distracting untill I understood what was happening, and now it is useful because between the rear screen and the EVF I can actually toggle the "FN" labeled button on the back to get full frame with no header or footer, and by tapping the shutter release I can gauge my manual exposure setting from the camera's "A" mode reading.
Once you get use to the lack of clutter in the EVF and rear display pretty much setting manual exposure is performed without a header or footer distracting you. I use the EVF and rear display kinda like a calibrated monitor. Just know that the default settings on the brightness I had to lower to match WYSIWYG. Default setting was the midpoint or a 50 on a 1-100 scale, I dialed it down to about a 30.
Now I'm spoiled. I go full frame/no clutter all the time now. Also the difference in resolution between my SL and SL2 is so vast that the added resolution not only speeds up manual focusing, but also is more accurate.
Pretty much I focus on fine detail that is not revealed on my old SL. I'm talking focusing on eye lashes instead of an eye using the zoom in. When I say it is like having an EIZO on the back of my camera it is not so much of an exaggeration.
Cal
