Perhaps he needs all the work he can find, even if it comes with baggage. 🙂
Is he a ‘true tech?’ 😀
Did you have Don modify the meter for a 1.5v battery? Did he send back with a battery init? If so, what was it?Ohhhhh that's right, I guess I knew that, duh. Anyway, DAG did a bangup job on my very nice 50 Jahre "Jubilee" M5. The meter is right on and it runs like silk.
Here is another with a 50/2 Summicron.BTW if anyone reading this thread gets struck by 5AS (M5 acquisition syndrome).... there's a chrome 3 lug, DAG serviced up on the Photrio site.
(not mine.....that one sold in '73 or so 😉 )
Here is the thread that @hap mentioned about the M5 light leaks, along with the technical note that I shared in Post #73 of said thread:I've used Youxin , DAG, and Sherry. Youxin is ok....I bought an M3 from him and a canon P. Recently, I had a Leica R 100 APO MACRo Elmar and he declined to clean....saying he had no knowledge of opening the lens. Sent to DAG who did the dirty deed and it was good, although expensive. I guess that is the issue Leica R lenses can be difficult. Don will answer emails and even calls. Sherry is hard to communicate with.
There is a thread regarding a particular M5 problem with light leaks. Nobody, not even DAG or Sherry could fix. Finallyl, the camera sent to Zacks Camera repair who fixed it with notes from a French language letter that was translated . A very weird sort of story.
www.rangefinderforum.com
My experience with DAG is that it's worth the wait and the price. That said, though, I've also had excellent service from YYE.
A 'true tech' may also realize that taking on someone else’s unfinished job could be a recipe for wasted time at a minimum, having to deal with potentially damaged parts that were the previous tech’s responsibility, missing (irreplaceable) parts, and who knows what else. Maybe the previous tech isn’t even a qualified tech, but a completely untrained hack! On the contrary, a legitimate 'pro' has likely already experienced the pain of accepting someone else's assembled hack project, it is perfectly reasonable and understandable to therefore reject a disassembled one.
I can completely understand if someone like DAG decided to skip such a project considering those of his caliber have far more work than they can possibly complete in a reasonable time as it is.
The heavenly M5 is such a Heavenly camera. A true Street photography monster workhorse.
It only lacks a winder/motor capability, but for the rest, it’s a champ.
People are uneducated regarding the M5, prefering to parrot what they read instead of simply trying it.
And yes, it is best used with small, tiny lenses. A 35 summicron V4 or V1 on that camera is perfection. My hands are all over that sexy combo.
That bottom left corner is totally made for left hand holding, and a tabbed lens such as a Summicron or summilux 35mm is ideal: the left hand holding the camera with index and thumb while position-focusing (pushing/pulling the tab) with the index or middle finger.
The right hand’s index is for pushing the shutter and to change the shutter speeds while NEVER looking away from the viewfinder.
The right hand’s middle or 4th finger can be used for pushing the focus tab towards close focusing.
An absolute shooter’s delight. The M5’s size is perfect for who is into street shooting. My hands are perfectly positioned. The camera’s shape is such.
Once I understood just how deeply the M5 was engineered, and modeled towards handling… I regreted having spent time with other Leicas so much. The M5 definitely is a Heavenly piece of engineering. Absolutely the equal, and many times better, than any M234…
I have sign in my shop to the effect of...And just a few days after I posted this, DAG himself responds to an inquiry about tampered gear and explains why he isn't interested, literally exactly as I described. 😉
DAG, no 'truer tech' ever existed...
Well, no, as you can see if you actually read the link, DAG will *not* necessarily agree to 'sort out a pile of bits and pieces,' and for quite good and valid reasons.
As far as Youxin not working on Leicaflexes or M5s, with a 7 month backlog without any of those, why would he necessarily want to add to his work load? He has chosen to focus on specific cameras, that's his prerogative, it's just a business decision after all.
My guess, Chuckroast, is that is what Don will do when I send my M5. I suspect I will use the alkaline and see how it goes. Othewise, I will follow in your footsteps with the dummy adapter and a silver oxide battery. My concern is that I've tried that before. I had to file down the adapter in order to get it in the battery well with the battery . The cover never did screw in flush by a long shot.I think he does this routinely as part of his CLA, but I would imagine he would do only that if requested.
Mine came back with a 1.5V "button" alkaline in it. I promptly removed that and used an MR9 style adapter (without any voltage dropping diode in it) so I could use silver oxide batteries to power the meter. These are preferable to alkaline because they fail all at once whereas alkalines slowly loose voltage.
