Sonnar Brian
The Konica S2 parallax correction also changes Field of View for distance. That, and the Zeiss finder on the Polaroid 250/350/360/450/180/190- are the few that have that feature,
They've never made a rangefinder in the past so I doubt they'd start now. The only ones making RF's at the moment are Leica and Pixii.Thanks so much for the reply guys ! I am looking for one with leaf shutter and can work without a battery, so some of the recommendations do not fit into that, but I know they are all great cameras. I wanted a leaf shutter camera becoz my Sovet ones got leak on the cloth curtain, and my photos got fogged, so that even Leica will have that problem sooner or later, the same reason I don’t want a bellow camera. The reason I do not want an automatic model is that electronic devices produced over 30yrs. ago will probably start to fail today, even if they still work it will take some re-adjustment, so that I would rather go with an external meter like those hotshoe mounted ones. Btw I am primarily a Pentax shooter, I like everything about it except one thing, their film cameras were mostly made with cloth curtain shutter that made me worry ! Pentax has just restarted film camera production, I do hope they will come up with a RF !
One thing that I want to note on parallax compensation, having used a lot of rangefinder cameras with them and without them, is that it's still very much an approximate framing device.
Thanks, I see what you mean. The first time I noticed the framing problem with non SLR was when I was shooting with a P&S at close range, the subject almost completely disappeared in the photo. Then later I watched a random YT review of the Konica IIIA to learn that it was one of the best RF with parallax compensation even Leica lacked, so I only looked for RF with such features. Btw, I am also interested in shooting medium format, and I learned that some TLR also have parallax compensation, I believe they also have the same limitation, so that I will keep in mind to shoot a little 'wider' to ensure to cover everything I want to include.Since already many great suggestions have been given I don't have much to add there.
One thing that I want to note on parallax compensation, having used a lot of rangefinder cameras with them and without them, is that it's still very much an approximate framing device. For once due to parallax (the viewfinder being offset to the lens) it does not work for objects that are near you. So, even though the frame-line move to compensate for closer focus it still presents a "best guess" as to what will be included in the picture and does not guarantee that what's outside of the frameline does not end up in the picture and vice versa. This is true even for the "mythical" Leicas.
Then adding to the inaccuracies there is also shrinkage, all lenses will actually change in focal length as it is focused closer throwing off the framelines as well. The only rangefinder camera that I know of that tries to account for focal length changes/shrinkage is the Fuji GW690 series.
Parallax corrected framelines will also not save you from stupid gotchas such as shooting through a fence and forgetting to move sideways, or having a wall that is under you show up in the frame because unlike the viewfinder, the lens does indeed "see" it... been there done that...
Basically if you need absolutely dead-on accurate framing, nothing will match a single lens reflex. If you don't need that I would not make parallax correction the deciding factor, for example my main cameras do not even have static framelines - just a peep-hole, but having shot with them for long enough I have a very good idea about what will end up in the picture and what won't.
Yes, you are right.With regard to cloth shutters and Pentax--your Pentax cameras will be SLRs, so the mirror will block the light from getting to the shutter, unlike an RF which has nothing between the lens and the shutter. I've been using Pentax cameras since the mid 1970's and have never had an issue with a shutter curtain developing a light leak. I grant you that Leicas and other RFs with cloth curtains can have that problem--I had to have a shutter curtain replaced on an M3 that I owned for while before selling it to finance a 90 mm wide angle for my 4x5.
Curtains are replaceable. Comparing to FSU (junk materials and build), Leica curtains, light buffle seal will last longer than you will be around. I had M3 DS ELC, made in fifties, original factory seal. No light leaks. New curtains and seal are available as quality product, not as Zenit old stock from eighties curtains.Thanks so much for the reply guys ! I am looking for one with leaf shutter and can work without a battery, so some of the recommendations do not fit into that, but I know they are all great cameras. I wanted a leaf shutter camera becoz my Sovet ones got leak on the cloth curtain, and my photos got fogged, so that even Leica will have that problem sooner or later, the same reason I don’t want a bellow camera. The reason I do not want an automatic model is that electronic devices produced over 30yrs. ago will probably start to fail today, even if they still work it will take some re-adjustment, so that I would rather go with an external meter like those hotshoe mounted ones. Btw I am primarily a Pentax shooter, I like everything about it except one thing, their film cameras were mostly made with cloth curtain shutter that made me worry ! Pentax has just restarted film camera production, I do hope they will come up with a RF !
Yes the "17" is crazily expensive, and I dun want it even for free. Pentax is one of the oldest brands with a long history in making film cameras, I just thought if new film cameras were to be reintroduced it must be something uncommon from the company.Curtains are replaceable. Comparing to FSU (junk materials and build), Leica curtains, light buffle seal will last longer than you will be around. I had M3 DS ELC, made in fifties, original factory seal. No light leaks. New curtains and seal are available as quality product, not as Zenit old stock from eighties curtains.
RF is even more complicated than SLR's mirror. Pentax could only make P&S now. Do not expect miracle to happen. They are charging ridiculous price for just a viewfinder. RF will cost much more, since Cosina most likely already destroyed their Bessa production, which was source for not to pricy RF blocks.
I was also hoping for more with the Pentax 17, but I understand that they are trying to market to young people and not older and experienced photographers like most of the people on this forum. My hope is that if it sells well that Pentax will make other and more sophisticated film cameras in the future, and that other manufacturers might jump in as well.Yes the "17" is crazily expensive, and I dun want it even for free. Pentax is one of the oldest brands with a long history in making film cameras, I just thought if new film cameras were to be reintroduced it must be something uncommon from the company.
As far as I understand Pentax is planning for more film cameras, please check the Pentaxforum or YouTube for the announcement. And I learn that Rollie is rolling out an AF model after the "35", but I've no interest on that. I believe most "old timers" have little interest on automatic models but enjoy the arts of mechanicsI was also hoping for more with the Pentax 17, but I understand that they are trying to market to young people and not older and experienced photographers like most of the people on this forum. My hope is that if it sells well that Pentax will make other and more sophisticated film cameras in the future, and that other manufacturers might jump in as well.
It looks like you didn't subscribed to their YT channel. In one of the first "17" videos and via web, they addmited of having no knowledge left for film cameras. They contacted older people to get explained how film advance mechanism works. The reality is if even they have all of the documents, nobody knew how to make it, except some oldest, not with company anymore. This is common corporate practice. One of the manufacturers I worked for has to ask some older customers how equipment they sold and not made anymore works.Yes the "17" is crazily expensive, and I dun want it even for free. Pentax is one of the oldest brands with a long history in making film cameras, I just thought if new film cameras were to be reintroduced it must be something uncommon from the company.
No I did not follow their YT channel, but I'm long time member of their forum. Do they need reverse engineering to get to know how a film camera works ? I think at least it is much easier for them than a relatively "new" camera company like Sony to produce a new film camera.It looks like you didn't subscribed to their YT channel. In one of the first "17" videos and via web, they addmited of having no knowledge left for film cameras. They contacted older people to get explained how film advance mechanism works. The reality is if even they have all of the documents, nobody knew how to make it, except some oldest, not with company anymore. This is common corporate practice. One of the manufacturers I worked for has to ask some older customers how equipment they sold and not made anymore works.
Sony has surpassed almost all old names in most used cameras a.k.a. mirrorless. If where would be real market for film, they are technically as good as Pentax. It is ground zero in both cases. But with film been down to the niche, it is good project for Pentax as niche manufacturer. It is nice to have Pentax still kicking around.No I did not follow their YT channel, but I'm long time member of their forum. Do they need reverse engineering to get to know how a film camera works ? I think at least it is much easier for them than a relatively "new" camera company like Sony to produce a new film camera.
Yes Sony is very advanced in digital camera design, and provides sensors to most of the digital camera manufacturers, but it relied on Konica/Minolta to produce their first "practical" DSLR, coz it has no previous experience in that area. Sony also partnered with Zeiss to produce their lenses, just like Microsoft with Adobe…etc. Unlike all other "real" camera companies that are deeply rooted in photography, so I don't think Sony can do better than Pentax if it were to produce a film camera with complex mechanical parts. And since new Pentax designers “lose track” on how to produce a film camera, it's a new start for them, so they may come up with something totally different ever in Pentax history. The problem is Pentax is too small a company in the photography business can barely survive today, luckily Ricoh which is the big boss behind is also rooted in photography, so there's still hope for them. And while developing the new K3 Pentax stated that they will stick with DSLR instead of mirrorless, that's shocking like killing themselves quicker, they even came up with the “17” and created quite a stir where others followed suit ! I always compare Pentax with Olympus, both have similar history in photography, and both OM and Ricoh produced RF in the pass….Sorry I go offtopic too much !Sony has surpassed almost all old names in most used cameras a.k.a. mirrorless. If where would be real market for film, they are technically as good as Pentax. It is ground zero in both cases. But with film been down to the niche, it is good project for Pentax as niche manufacturer. It is nice to have Pentax still kicking around.
I am just curious and want to play with it ! I don't have any leaf shutter camera beside P&S, and bcoz I don't trust cloth curtain shutter, so I give leaf shutter a try. And btw, when searching for a good vintage RF I came across the Retina IIS, I like it more than the IIIS bcoz it has a wider lens. I don't need changeable lenses but a capable film camera for casual walk around shooting, if I want more I can use my Pentax SLR. There is something I am not sure about the IIS, does it have automatic parallax correction built in ? I mean moving frameline during focus. I got mixed results when searching for an answer, since Retina is the high end series I believe and I hope it has that feature. Another thing is, it has a meter coupled exposure system locked to the EV, and can be calibrated with the turning wheel below the lens, but what if the meter failed, can I still use the wheel to adjust the exposure with a light meter ? or to release the EV lock to adjust shutter and aperture independently ?I’m curious about such a particular feature set. What will you use the leaf shutter rangefinder for?
