Leica I service manual/advice
Hey guys, thank you very much for your help! I have some experience in repairing old cameras but I am not an expert at all, so I am always very thankful if I can benefit from other's experience 🙂
@GMOG Does this camera disassembly also apply to Leica I?
Best regards,
Vincent
Funny thing seeing this thread pop up now. I'm in the process of taking apart my 1930 A, a crusty example that was exposed to sea water. I think that with fresh curtains and a proper cleaning of all parts it will work again. If anyone has questions about getting into one of these oldies maybe I can help.
That looks familiar....
This is what I found under the leather jacket of a Leica I(e) a few years
Assuming that you are asking about the Fedka guide I linked to, yes, because the Russian cameras were close copies of the Leica IIIa. After removing the rangefinder from a Zorki I/Fed I/IIIa the rest of the camera is similar. The shutter and film advance designs are almost the same. Not all details of the Fedka guide apply but many do. Using it with the diagram from the spare parts list might be enough to get you through. I'm not familiar with Ed Romney's book Leica Camera Repair but it is probably worth checking it out if you can find or borrow a copy (or maybe someone here could scan the relevant pages?).
Here's a copy of the Leica parts diagram:
Leica camera repair handbook, by Thomas Tomosy, Amherst Media, Inc. 1999.
All books by Kuramochi Nobuyuki (Nobbysparrow), eBay
Leica m2 repair (military repair manual) http://www.edromney.com
Sadly I cannot find the book anywhere. Anywhere which sells this kind of books?
Try to get the books by Kuramochi Nobuyuki (Nobbysparrow) on eBay. If he is still in business and live and well he'll surely send you the books. They're in English. Ask him for his "repair books".
I love Nobu. Always the cheapest prices and Japan has the most fastest mailing service of the World. Items come to me From Japan to Turkey in 4-5 days most of the time.
Do you know if it is possible to get into the viewfinder to remove dust and years of stuff?
Mr_Flibble, What did you use to recover that oldie of yours? The only product I can find for these is from Hugo Studio, but the material isn't as thick as what came on my I Model A originally. The replacement covering is said to be 0.5 - 0.6mm thick. The original is about 0.8mm thick. The difference will impact focus due to the lens being mounted on top of the covering. Of course, I can make a shim but if I don't have to . . .
This is the eBay listing for the HS covering:
PS - I was incorrect in post #44 in comparing the Zorki I to a Leica IIIa. That should have been Leica IIa.
I got the new skin from Hugo, because it was the only place that had them for this style Leica I(e).
Strange, the Leica I(a) I have has been reskinned (and repainted). I can't quite make it out, but it looks like they cut away the vulcanite around the lens ring and left the vulcanite spacer under the lens in place. And then just put the new skin around the shell.
Thanks for the reply. At least the HS covering is thinner instead of too thick. I like the idea of leaving the original Vulcanite under the lens mount but the material is very brittle and I don't think I could cut it to fit nicely. Making a shim would be cleaner. I'll figure it out when I get to that point. In the meantime I'm going to order the covering from HS. Thanks again!
