Glenn2
Regarding the flash connectors, I have a Nicca 3S which has an identical pair of connections on the front in the same position.
I believe one is for electronic flash and the other for old style bulbs that needed to reach peak output before opening the shutter.
Looks likely that someone modified the camera to flash sync in a similar way. Leicas have the little dial under their shutter speed to set delay on later Barnacks so only need a single connector on back.
