Flash Advice for Minolta CLE
matteo29103
12:32 PM
Switzerland
Hello guys!
I’m Matteo and I’m new on this forum, I hope you can help me a bit with a little problem I’m having recently. Are two months from now on rhat I own a Minolta CLE with a nokton 40 mm and I was thinking to use flash for street photography. I tried just to see if my Contax TLA140 works on it and I saw that if I align the center Pin it just fire from the 1/30 shutter speed till the Bulb mode, but it never fire at the syncro shutter speed (1/60). I decided then to not use it for this problem but also because I was worried that it could ruin the contacts of the camera. So I devided to buy the Reflx Lab Flash and guess what? same problem. I went to a camera shop here in Switzerland amd a person told me that i need to use a flash with an attach of three pins, I searched on internet and I’ve found out that I can use old Minolta’s flash of the x series as is written on the manual for the CLE. In the meantime I tried with another flash with three pins this time, it is a Canon Metz 24 and it give always the same problem as i wrote before. Do you think I is a matter of using the electronics of the same brand? (Minolta) Or I should give my camera on repair?
Thank you for the attention!
No first hand experience with the CLE:
BUT
Minolta made a dedicated flash for it. The extra pins that connect the meter of the camera to the flash: no industry standard. Often dedicated to a camera/flash combination.
I can't say if the camera needs repair or not: but I do believe the dedicated flash is required to allow the camera's meter to operate with the Flash electronics.
Something must be wrong on your CLE. I have the Reflx lab flash and a Minolta electro flash 3 with the standard one pin flash for the hot shoe and both work at 1/60 on my CLE.
I do have a later flash, the Maxxum 1800 AF, but I have not film tested it, that one I read was supposed to work with TTL metering, but I just havent had a chance to use it on film.
I don’t know the CLE, but out of interest does it fire at higher speeds? Obviously it won’t synch but most cameras I have had will fire a flash at any speed.
I just tried out the Reflx lab flash again and the Minolta AF 1800 Flash on the CLE and it seems past 1/60 the flash does not fire if the speeds are not manually set. At 1/60 and below the flash fires.
Does the CLE offer the same system for TTL (through the lens) flash metering as for the X-700 and X-570/500?
If so, you need to use a Minolta PX series flash. Other brands offered dedicated flash for different brands of camera, as well. I have a Vivitar 3700 flash, bought in 1984, with an attachable flash module dedicated to Minolta PX. On the Vivitar flash module, it says DM/M-TTL.
I don't think Minolta made the only 3-contact flash, so if you get a 3-contact flash dedicated to another brand, it might damage your camera. You need to make sure that the 3-contact flash is dedicated to Minolta.
- Murray
I use a Minolta Auto 280PX with my CLE. Works just fine under 'A' for Auto. However, double check to ensure your subject is within flash range before you start taking pictures. Here's a few pics of both the flash unit and the camera and flash. I have the manuals for both the flash unit and the camera, so feel free to ask any questions. BTW, I just love that Voigtlander Heliar 40mm lens. It's just insanely sharp..
..Avery
Thank you so much!
The Flash is really big for the camera?
Minolta had a much smaller version specifically made for the CLE (called the Auto CLE, with a guide number of 14), but this Auto 280 PX was actually made for the Minolta 700. Any of the PX series flash units would work with the CLE though. When I went looking for a compatible flash unit a couple of years ago for the CLE, the Auto CLE flash unit wasn't available anywhere..
..Avery
..Avery
View attachment 4850899View attachment 4850900
You are correct. Minolta auto 280px should be fine. If you wish, I suggest you call Scott Nielsen and ask him. I bought a Minolta flash for mine...but i've never used it. Really nice guy and knowledgeable CLE
