Nikon S2 holder for eye piece correction lens
Alpsman
2:48 AM
Austria
For some unknown reason, the viewfinder of my S2 is becoming increasingly blurry 😉
To remedy this unfortunate situation, I spent a few hours playing around on the computer (and messed up a number of prototypes) and designed a mount for the normal Nikon correction lenses.
The mount has an M19 x 0.75 mm thread, so all correction lenses for Nikon F, F2, FM, FE and of course every correction lens (Fuji, Zeiss) that has an M19x0.75mm thread fit.
Printed with PLA and a layer thickness of 0.1 mm or less so that the thread is nicely formed and 4 perimeters so that it is stable.
The "first time" screw the lens in carefully and straight so that the thread does not cut into the plastic.
Download here for free:
That's very clever and nicely done. And it is very generous of your to share this with all of us.
I too found the viewfinder on my Nikon S2 was getting blurry. Having the same problem on all my favorite old film cameras. Unlike the digital cameras I own, which have adjustable diopters, the old film cameras are fixed viewfinder, when your eyes age, tough luck.
Best,
-Tim
In the meantime I even make the corrective lenses myself; see this thread.
Because you either can't find a suitable one or they cost a fortune.
Next I'll try to design and print such a ring. The problem is getting the fine thread to fit.
Interesting! So the new eyepiece stands proud of the camera's eyepiece, i.e., not touching? How do the frame lines appear to you -- well visible, or requiring looking up/down/left/right? I expect to see your product(s) on Etsy soon!
The first thing I did was, holding the correction lens to the camera by hand to see if it works.
Yep!
The framelines are as sharp as before, but the image in the viewfinder is also sharp and I can see the patch for focusing clearer than before.
I can only speak for my eyes. On my regular glasses I have on the right eye +3,5, but on the camera I need a + 0,5 to +1 correction lens.
Then I made a sample out of cardboard to get the correct form and measurements.
The rest was done in the software and on the printer.
And no, it was not a one-shot development.😉
On the S2 I need a + 0,5 correction lens as I do on the F/F2.
The correction lens does not touch the camera eyepiece, because the material is thick enough to touch the camera body before the correction lens touches the cameras eyepiece. I only have a + 0.5 and a +1 correction lens for testing. Maybe a thicker / stronger lens will need a greater distance.
As soon as my eyesight gets weaker I need also stronger lenses.
Then we'll see if I need to rework it.
Unfortunately I don't have a lens with M 21x0.75mm like on the F3HP, otherwise I would have made two versions.
The framelines are as sharp as before.
At least "I" can see the whole frameline without moving up/down/left/right
I dont sell it on etsy or somewhere else. I dont do "it" for money ;-)
I do it just for the sheer fun of creating things I don't find or get to buy for money.
Ya can download the holder and a few other things for free
and have to print it by yourself or by a friend who have a printer or a friend who knows a friend who have . . ..
Thanks, Alpsman. In fact, our local library has a printer that the public can access, so maybe I'll educate myself a bit more and see what I can create -- thank for the info on Printables.com
There is an M19x0.75 ring available for download here.
In my slicer and on my printer I had to scale the ring to 102% so that it would fit.
Now all you need is the right glasses for a lens.
