boojum
Ignoble Miscreant
@vvilliam Great Choice! Be sure to post some pictures taken with it.
I am sure we can come up with suggestions for lenses to put all those selectable framelines to use... Trust Us!!!
Just step over this way. Bring your wallet. ;o)
rfaspen
[insert pithy phrase here]
Soooo many lenses. Tell us what you want to do.
More fun to spend someone else's money? Sometimes. But I sure do like shopping for yet another lens
vvilliam
I'll hold off on lenses for a while I think. I love the 40mm f1.2 on my sony, so I'm, pretty comfortable working in 40mm.
I might get a 50mm in the future, or go wider with a 28mm and a viewfinder.
First things first, I gotta get some film through this to check the rangefinder accuracy, lightleaks, etc.
vvilliam
Loving this camera!
Just finished my first roll and wasn't too sure things would be in focus. Turned out pretty good!
The only problem I have with the R3M is that the frame counter is a bit finicky and seems to be stuck. I've tried opening the door when loading new film but it won't reset.
wlewisiii
Just another hotel clerk
vvilliam
There should be a small latch under the door. Sometimes grime will cause it to stick. Open the door, take a look. I've cleaned the latch on other cameras with a little alcohol to allow it to move freely. Worth a look.
@vvilliam
I tried to press the latch a few times when the door was last open, is there a trick to it?Yep, see the little silver bit in the edge where the door closes? That's what should move back and forth to reset IIRC from my Bessa R a lifetime ago. This is an internet picture of a R3M like yours.
Should it be pretty easy to press down? It felt like I needed almost a half a pound of force to get it to go down, maybe it's stuck up?
Is there any other control I can press or play with to loosen it?
The latch should be easy to press IF it is in the correct position. It sounds like it is getting stuck in the down position, and not coming up to the correct position with the back open. In that case- do not force it. Post a picture showing the extension of the latch when the back is open.
vvilliam
@vvilliam
Thanks I think that was it!The latch should be easy to press IF it is in the correct position. It sounds like it is getting stuck in the down position, and not coming up to the correct position with the back open. In that case- do not force it. Post a picture showing the extension of the latch when the back is open.
It was stuck Up actually, and I noticed that it would only depress when the advance lever was being operated.
I manually cycled it a few times and pressed it when it gave and now it no longer sticks up when the lever is fully closed.
vvilliam
Overall I think I'm really liking the rangefinder experience.
It took a bit of practice but now it's becoming second nature.
It's easy to bring up to my eye, frame, and focus. And I feel very present in the moment.
I thought people were being pretentious when they talked about these things, but there are definitely some non-tangible qualities to using a rangefinder.
Godfrey
somewhat colored
Glad to hear the rangefinder is resonating with you. Enjoy it, use it a lot until you barely notice it ... and then get on with Photography. That's what I find them really good at...
G
G
rhl-oregon
Cameras Guitars Wonders
vvilliam
I've shot a few rolls now, where's the best place to post photos? The gallery? Is there a thread?
AlwaysOnAuto
You have a Sony?
Which 40mm lens?
Which 40mm lens?
vvilliam
For my Sony I have the CV E-Mount 40mm F1.2.You have a Sony?
Which 40mm lens?
It's easily my favorite lens for that camera.
AlwaysOnAuto
Which Sony?
vvilliam
The A7CR!Which Sony?
lots of options:I've shot a few rolls now, where's the best place to post photos? The gallery? Is there a thread?
- start your own photo thread
- post in the gallery
- reply with a post in existing photo topic threads
Godfrey
somewhat colored
I post photos to my account on Flickr.com and link them here and to various other forums for sharing. It's pretty easy to do and nets one repository for my photos on-line rather than half a dozen different threads, galleries, etc.
G
