kiemchacsu
I have some bottles of HC110 made by SINO and TETENALCorrect, Sino produced the new version which is water-based not glycol based. The old version is not produced by anyone anymore.
Marty
Just looked through to confirm and found out that SINO version is EXACTLY THE SAME as the TETENAL one, which is glycol base.
I snap the ingrdients for proof,
check it out. The first photo is snap of TETENAL bottle to compare.
Freakscene
Obscure member
This is a list of contents, not a formula. They are not the same. The proportions of the organic alkalis are different and the principal solvent in the Sino version is water which contains sulfite, not glycol containing liquid sulfite as an organic complex. Measure the viscosity, or the sodium content. The proportions of catechol (1,2 benzene diol) and hydroquinone (1,4 benzene diol) also differ.I have some bottles of HC110 made by SINO and TETENAL
check it out. The first photo is snap of TETENAL bottle to compare. View attachment 4835985
The MDS for each product demonstrates much of this:
Detailed and discussed here:
The results are the same but the formulas are different.
Analysed here:
Marty
kiemchacsu
Analysed here:
Marty
I totally got your point here that the OLD and NEW formulars are different.
But the key point here is: we are not sure whether SINO was making the OLD for NEW formula.
Looking at the viscosity I found the SINO one and TETENAL one are no different and it's quite thick.
That's why i SUSPECTED that it's the old version.
A guy here also share the same thought with me.
Kodak yellow HC-110 in round bottle - 2022 - Sino Promise, Made in China
{Moderator's Note: for discussion about the previous, 2019 version of HC-110, and its differences from what preceded it, you may wish to revue this thread: https://www.photrio.com/forum/threads/new-hc-110-developer-not-the-same.176138/} Hello guys. I just bought a bottle of Kodak HC-110 in...
Freakscene
Obscure member
The Sino Promise bottle I had was definitely the new formulation with much lesser viscosity. Sino might have packaged or labelled the end of the Tetenal manufacturing run, but I doubt they had the technology to manufacture the old formula. If you really want to know, check the water content of the developer you have using copper (II) sulfate or cobalt chloride.I totally got your point here that the OLD and NEW formulars are different.
{Moderator's Note: for discussion about the previous, 2019 version of HC-110, and its differences from what preceded it, you may wish to revue this thread: https://www.photrio.com/forum/threads/new-hc-110-developer-not-the-same.176138/} Hello guys. I just bought a bottle of Kodak HC-110 in...www.photrio.com
Marty
Freakscene
Obscure member
Some further research uncovered some interesting evidence:
This is a “Made in Germany for SinoPromise” bottle of HC-110. It is the old formula (and I see it being sold as such in several places). It is possible that there are other variants, but the product I looked at in the round SinoPromise bottle with Made in China on it was the new formula, and I really doubt that SinoPromise made any of the old formula, but who knows how what was packed and labelled?
As I said, test for water, or measure the viscosity against a known standard.
kiemchacsu
My German made HC-110 for SINO is also the last batch of the old formular in old shape bottle that I have (EXP 2023),Some further research uncovered some interesting evidence:
Current SINO made in China has expire date of 2025. Still no way to test for water as I dont have any special tool for that.
Just pure my judgement from looking of the color and the viscosity.
Freakscene
Obscure member
Glycol-based HC-110 is back, courtesy of Adox/Fotoimpex: 📣 ADOX HC-110 Professional
PetPhoto
how long does your stock mixture last though? you know, the "mix x amount of concentrate with y amount of water. then use the below chart to make the working solution"I am currently using Ilfotec HC (1 litre bottle decanted into 100ml medicine bottles) and it is 3 years old with no sign of deterioration. I use Calpol childrens paracetamol bottles and they come with an oral medicine syringe and fitted stopper.
Untitled_254019GB by E.J. Bragg, on Flickr
Freakscene
Obscure member
Most users these days omit making a stock solution and measure syrupy developers using a syringe and dilute directly from syrup. That way the longevity of the stock doesn’t matter.how long does your stock mixture last though? you know, the "mix x amount of concentrate with y amount of water. then use the below chart to make the working solution"
PetPhoto
what, and not follow the ilford directions... thats heresy i say, heresy. Ill bring the torches. someone else needs to bring the pitchforksMost users these days omit making a stock solution and measure syrupy developers using a syringe and dilute directly from syrup. That way the longevity of the stock doesn’t matter.
Freakscene
Obscure member
You are following Ilford’s directions, just skipping the less stable stock solution.what, and not follow the ilford directions... thats heresy i say, heresy. Ill bring the torches. someone else needs to bring the pitchforks
WoodallP
Pragmatist Barnack lover
Don't waste the pitch, it's great for making your developer syrupy!what, and not follow the ilford directions... thats heresy i say, heresy. Ill bring the torches. someone else needs to bring the pitchforks
PetPhoto
all of ilford directions for making that final working solution come FROM diluting the stock solution. I know its popular for HC-110 users to do straight from syrup but mathematically it only works for specific dilutions.You are following Ilford’s directions, just skipping the less stable stock solution.
I can get over developed negs on xp2 super using 50ml of stock to my paterson tank... id hate to see what comes from using 50ml of straight up syrup in a paterson tank.
FotohuisR
I have checked the old type Kodak HC-110 and the HC-110 made in Germany for Sino, both in the same type bottles but there is a difference in viscocity. In general the same chemicals are used but somehow they are different. BTW Tetenal was already (again) in bankruptcy last year.
kiemchacsu
Currently on Taobao, there is HC-110 Clone which is "KOIMAGE HC-110" Has anyone tried this one? The bottle shape is similar to the SINO rounded one.
