Camera Repair Horrors: These are the models that give repairmen agita.
A rogue’s gallery of cameras that are tough to put back in working order.
By Jason Schneider
Not all cameras are created equal when it comes to repairing and servicing them. Some models are blissfully straightforward and accessible, others are devilishly complex and require extensive disassembly just to get to the problem area, and most fall somewhere in between. We asked three experienced camera repair experts (two men and one woman) which cameras they dreaded repairing. Here’s an overview based on their hands-on experiences.
In general, cameras that are idiosyncratic and mechanically complex are the most time consuming and challenging to repair. A classic example is the Kodak Ektra of the 1940s, the Rochester NY-based company’s first and last attempt to build world class rangefinder 35 system. While the Ektra had its good points—a full line of superb breech-mount Ektar lenses, interchangeable film magazines, and a long base, mil spec coupled rangefinder—its horizonal focal plane shutter was inordinately complicated. Rather than using a traditional timing mechanism with the first and second shutter curtains wound (tensioned) simultaneously (as in, say, a Leica), in the Ektra shutter the first shutter curtain is wound over a longer distance than the second one to set the slit width that determines the shutter speed. Supposedly this provides superior accuracy, but the Ektra shutter was notoriously unreliable and difficult to adjust and was the main reason that the Ektra, first announced in 1941, was phased out in 1948.
Kodak Ektra of 1941 to 1948 was Amerca's fist and last attempt to build the world's most advanced rangefinder 35. It was done in by its unreliable shutter.
Early Bronica 6 x 6cm SLRs, namely the original model Z of 1959, the tweaked and marginally more reliable model D of 1960, and the stripped down and simplified Bronica S of 1961, are all considered hard- to -repair compared to a typical medium format SLR like a Hasselblad or a Pentax. All have idiosyncratic shutter and mirror mechanisms that are tough to repair and adjust. Each employs an unconventional instant-return mirror that flips down before flipping back up to viewing position and has an extra curtain that moves in place over the flipped-down mirror to prevent light reflected from the finder from fogging the film.
Bronica DeLuxe model Z of 1959 was an audacious attempt to outdo the Hasselblad, but it was complex, delicate, and not very reliable.
The Bronica S of 1961 was a simplified, much more reliable successor to the Bronica Z and D, but its complex mirror and shutter mechanisms are hard to repair.
Late model Alpa 35mm SLRs, including the Alpa 9d, 10d and 11-series models, also fall into the hard-to-repair category. Having such unique design features as a front to back wind lever and a front-mounted shutter release, it’s often harder to access and repair certain components. Also, these cameras were bench assembled in small quantities and some repair components, especially electronics, are no longer available. Surprisingly, early Alpa 35mm SLRs and their progenitor the Bolsey Reflex, are not as bad as later models when it comes to repairing them and adjusting them to spec.
The Bolsey Reflex, progenitor of the Alpa 35mm SLR line, was designed by Jacques Bolsey (aka Bolski) in the '40s. It's fairly easy repair, unlike later Alpas.
Early Alpa 35mm SLR of the late '40s, early '50s. Conceptually complex, it was easier to repair than later models with built-in metering.
Alpa 10d of 1968 had an integrated pentaprism housing and a second meter needle in a window in the accessory shoe, Like the 9d and 11e, it's tough to repair.
Leaf shutter 35mm SLRs such as the Kodak Retina Reflex, Voigtlander Bessamatic, and Contaflex (all models from their respective makers) are challenging to repair due to their complex mechanisms with tight tolerances and potential for lubrication problems such as oil contaminating the shutter blades. Leaf shutters are inherently more complex than focal plane shutters, and they have many small intricate parts that can be easily damaged if not handled properly. Also, fewer specialized repair technicians are now available to work on leaf shutter SLRs and finding spare parts can be problematic.
Original Kodak Retina Reflex Type 025 of 1957 had component interchangeable lenses. It's well made and competent but a bear to repair.
Kodak Retina Reflex IV of 1964 to 1967 has an aperture display window on the pentaprism housing and fully interchangeable lenses, but it's still a bear to repair.
Contaflex Super B of 1963 had shutter-priority AE and interchangeable film backs, It's a nice camera, but like ill leaf shutter SLRs it's female dog to repair.
Zeiss Contarexes: All models, even the meter-less Contarex Spezial, are mechanically extremely complex. For example, the original Bull’s-Eye Contarex includes nearly 1100 parts, with seven principal alloy castings and additional stamped cover plates just to complete the basic structure. It’s rugged all right, and the aperture mechanism uses durable roller bearings (!), but repairs require a specialist, and 43 parts must be dismantled just to remove the top plate to gain internal access!
Zeiss Bull's-Eye Contarex with 50mm f:2 Carl Zeiss Planar lens...jpg
Zeiss Bull's-Eye Contarex of 1959 to 1966 with 50mm f/2 Carl Zeiss Planar lens. This ponderous hulk of camera is beautifully made but has 1100 parts!
Zeiss Contarex Spezial with 50mm f:2.8 Carl Zeiss Tessar lens..jpg
The Contarex Spezial, launched in 1960 has no meter and requires no batteries, but its mechanical complexity puts in on the hard to repair list.
The ultimate repairman's nightmare? A good candidate is the twin lens Contaflex unveiled in 1935. It may well be the most complex camera Zeiss ever offered.
Limited production specialty cameras. By their very nature these are idiosyncratic designs, and many are mechanically complex and offer unique features. Few repairmen have experience working on them, many are unwilling to take a chance on trying to repair them, and repair manuals and parts are often unobtainable, all of which make them challenging to repair. There are literally dozens of cameras that fall into this category but herewith the details on three classics:
The Compass of 1937 is an exquisitely made, super-compact 35mm camera (2-3/4x2-1/8x 1-1/4 inches, 7-3/4 ounces) camera designed by Englishman Noel Pemberton-Billings and made by the famed Swiss watch company Jaeger-LeCoultre. It takes tiny 24x36mm glass plates, has a rangefinder and ground glass focusing, a 35mm f/3.5 Tessar-formula lens made by Kern, shutter speeds 4-1/2 to 1/500 sec, and a built-in extinction-type meter. Though highly idiosyncratic and not very practical, the Compass is the ultimate compact 35mm camera of all time. Fewer than 5000 were made, so it’s relatively rare and quite pricey. Average, about $4000, though pristine examples and complete outfits have fetched much more.
Compass Camera made by Jaeger-Le Coultre watch company. Introduced in 1937 it may be the most exquisitely complex 35s ever made, and is a bear to repair.
The Tessina is an ultraminiature twin lens reflex camera made in Switzerland by Sigrist that was distributed by Concava S. A. for about four decades starting around 1960. It uses 35mm film in special cassettes, providing a 17 x 21mm format, and has spring motor film advance. There were three models, the 35, 35 Auto and 35L. The L model had the lens mounted on the top, in place of the finder, perhaps intended for covert picture taking. All models feature a Tessinon 25mm f2.8 lens, have shutter speeds of 1/2-1/500 sec, and a metal body with rounded ends measuring about 2½x2¼x1 inches. There’s a two-frame flip-up viewfinder on top and beneath it is a reflex, waist-level finder. The elegant Tessina (any model) is a coveted collector’s item that currently sells for about $400-$600,
The Tessina is an ultra-miniature twin lens reflex camera made in Switzerland. It has spring motor wind, uses special cassettes, and is tough to service and fix.
The Kodak Bantam Special that debuted in 1936 is an art deco masterpiece designed by Walter Dorwin Teague, The Bantam Special was the top-of-the-line Kodak camera based on the 828 format; basically an 8-exposure roll of paper-backed 35mm roll film without the usual perforations that provided a 28 x 40mm format. A beautifully made folding rangefinder camera, the posh original Special had an uncoated 50mm f/2 Kodak Anastigmat lens in a Compur-Rapid shutter, and the prized 1941 model had a coated (!) 50mm f/2 Ektar and Kodak’s own Supermatic No 0 shutter with speeds of 1-1/400 sec plus B and T. Despite its impressive specs, its front standard is not a paragon of rigidity, and lens sharpness at wide apertures was so-so. A collector’s heartthrob (either version) it goes for $250-$550 depending on model and condition. BTW, while 828 film is long out of production, fresh custom-rolled 828 is available for about $20 in black and white and $26 per roll in color negative.
Kodak Bantam Special of 1936 to 1940 with 45mm f:2 Ektar lens in Compur-Rapid shutter..jpg
Kodak Bantam Special of 1936 to 1940 with 45mm f/2 Ektar lens in Compur-Rapid shutter. An exquisite art deco camera, it took 828 film, is difficult to fix
Are some cameras relatively easy to repair? Thankfully, yes, say the repairmen we spoke with, although all can present challenges, and not every broken camera is worth repairing. Here’s a short list of “easy to repair” cameras suggested by our trio of camera repair experts:
Pentax SLRs, e.g. the Spotmatic and Spotmatic F
Asahi Pentax Spotmatic with 55mm f:1.8 Super-Takumar lens..jpg
Asahi Pentax Spotmatic with 55mm f/1.8 Super-Takumar lens. It's simple, straightforward, gorgeous, and east to repair, a great combo!
Nikon F and F2
Nikon F Photomic T with 50mm f:1.4 Nikkor-S lens..jpg
Nikon F Photomic T with 50mm f/1.4 Nikkor-S lens. This classic F will probably outlast its owner and its straightforward design makes it easy to repair.
Nikon FM2 (but not the early FM that used “fishing line” to control the shutter dial!)
Leica M series: easy to work on despite their range/viewfinders, which are complex, but straightforward and easy to adjust.
Yashica 35mm SLRS
The fact that some cameras are such a bear to repair while others are commendably straightforward and far less labor intensive raises an interesting question: Should camera repair experts be included in the camera designing process? It sounds like a great idea, but if they were brought in too early, could they stifle the open-ended creativity of the design engineers? Perhaps a camera repair person should be present through the entire camera design procedure so he or she could sound the alarm when complexity overtakes common sense. One alternative: since all cameras must eventually be serviced and repaired, perhaps camera manufacturers should make it a priority to educate their designers and production engineers to be cognizant of the needs of the hapless technicians that will have to work on their masterpieces when they need attention.
I was following rangefinder.ru thread about self-CLA of Contax IIa. They use Yahoo group were it was described. Person in Moscow who followed those instructions never worked on cameras before. He succeeded. I was holding this serviced Contax II in my hands in 2016. It was very smooth to operate.
Oleg CLA'ed the Contax II and attached Zeiss 5cm 2.0 for me. It is a smooth machine. It was gifted to me. It is marvelous. It is a '36, almost a century old and a mechanical jewel.
I just watched a YouTube video series in which Retina wizard Chris Sherlock rehabs a Kodak Bantam Special, and he didn't seem agitated at all. The design seemed slightly unusual, but basically simple and clever. Of course Chris is of the rare breed who can bring a basket-case Retina Reflex to heel without a tremor...
The last paragraph is spot-on. Engineers should consider ease-of-repair for any product they design. Many cases where a minor design change simplifies operation and maintenance of the device. This aspect of product design is often overlooked, leading to the repair technician rightfully screaming "What idiot designed this!"
I've said it before, and I'll say it again: Zeiss were absolute bastards for this.
It's no surprise to me that multiple Zeiss cameras are on Jason's list. Their design ethos seemed to be "we're fantastic engineers, so no one will ever need to repair or recalibrate this." Leitz' design ethos, on the other hand, was seemingly "this will need repair or recalibration through its life, so we'll make it as easy as possible to do that."
I made the mistake of buying a Contaflex (the leaf-shutter SLR version) on a trip to Romania last year - a £5 or £10 junk shop find in lovely shape. Got it home to find the lubricant in the shutter doesn't like British temperatures (it fired fine in a Romanian summer!). Weirdly, it'll fire fine when held in portrait orientation with the rewind knob down. No technician I usually send cameras to will even touch it, and I found a teardown diagram only to realise I definitely don't have the skills to get into that damn mess... On the shelf it goes.
See if @Sarcophilus Harrisii takes on work. He’s a pro with these.
Depending on which version of contaflex, what I did to one of mine was take the front lens element off, get a bowl of lighter fluid out on the patio and set the lens down into it so that the offending elements were submerged in it, bathing in it, for several hours. Then, exercised it. Repeated until loose. Then worked a small amount of a mineral oil into it to get it lubed up again. Worked well enough for cheap C41...
Mine's the Contaflex Prima. I think the issue is further in than that "technique" would manage to reach... the mirror moves freely, but the shutter doesn't open at all at any speed unless the camera is held vertically (or, as I've just learned, upside down). Very odd.
Thanks for the heads up. Sadly I can't see his profile or send him a message, so I presume he's blocked me for some reason!
Talking about the Nikon FM fishing line arrangement, the British made Agiflex 6x6 camera from the late 1940's has a similar construction. I once opened one of those and when I realized the near impossibility of getting it back together with the fishing line in its place, I just closed it up and put it on display. There is a story of one technician who tried to fix one of those cameras who got so frustrated that he threw the camera out the window. Mind you, the window was not open...........
Isn't this the camera my lens is from?
approximately M39
photo_2025-04-28_18-11-35 (4).jpgphoto_2025-04-28_18-11-35 (3).jpgphoto_2025-04-28_18-11-35 (2).jpgphoto_2025-04-28_18-11-35.jpg
My understanding is that the Contax I is not difficult to repair- it is difficult to keep it working properly. I think the Contax II is difficult to repair due to complexity.
Am I wrong?
I don’t think the Contax II is particularly difficult to repair. The only thing generally that can go wrong is the ribbons breaking, and I replaced them with ribbon from the fabric store back before there was an Internet to order stuff from. It’s not that hard.
The postwar IIa is more prone to having shutter problems; it’s repairable, and you’ll probably have plenty of practice from repeated entries by the time you have it fully sorted. Aligning the misaligned IIa rangefinder is a bit by guess and by God.
My Argus C3 is the only camera I own that I can get into, fiddle around, and get out of, and it works. I guess it is my deserted island camera.
My Pentax K1000 is another long time favorite of mine. It is a Spottie with a different lens mount.
But I also love my Contax II. It is very reliable now, but it cost me a small fortune to get it overhauled.
I think he has made himself invisible.
The World War II Jeep may have helped us win the war, but it was a terrible vehicle and, to coin a phrase, unsafe at any speed. Suspended like a 14th century ox cart it bounced around on rugged terrain, had a tremendous amount if play in the steering, and would flip over if you looked at it funny. GIs did learn how to drive the Jeep and stay alive, which may be one reason they're known as The Greatest Generation. As a teenager, I lusted after an original Willys Jeep, but then I drove one (purchased brand new in Cosmoline for $199 by my buddy, a mechanical engineering student at RIT) and was seriously underwhelmed. In comparison, my oversteering, underpowered 1955 VW bug was a masterpiece of modern engineering.
It scares me to think that I am old enough to have ridden in an original Willys jeep when I was a teenager
To add to what Rick said, I don't think you can make blanket statements like this across Contax models.
(To be clear I am not disagreeing with anything Rick said, just adding to it!)
The Contax I v1 (a) and v2 (b) are *very* easy to repair. They are also very reliable.
They have no slow speeds. The shutter is a very simple affair. They are quite simple cameras actually.
The trouble started when Zeiss realized they had to catch up with Leitz and add those slow speeds in. And do so quickly and hurriedly in a design that did not originally plan for them. This also meant they had to change the rangefinder assembly around and resulted in the cameras (model 3 to 5 or 6 depending on who you ask) which gave the I series their reputation. And let me say - deservedly so.
Things calmed down by the Contax I v7 (f) and it's quite reliable - maybe not as reliable as the v1 and 2 though.
The Contax II basically incorporated all the painful lessons learned in the Contax I debacle and is a very reliable camera - once repaired properly. The latter models in the series added improvements that reduced some of the small variances in shutter timing, which is nice to have but does in my experience not affect reliability. Also the ribbons usually last decades, I had a II which stopped working this year - upon repairing it I found it still had the original 1930 ribbons!
The Contax IIa series is reliable-ish since they do not have ribbons that tear, however once the shutter gums up your top speeds will start to go. Hence most cameras either have fading (or completey unexposed) top-speeds or have the shutter cranked up to such tension that the camera is probably not long for this world either. However unlike the II they will keep working, at the exclusion of the top speeds... hence my "reliable-ish".
I completely agree with Rick that the IIa rangefinder misalignment (predominantly on black dials, they used better cement later on) is an absolute nightmare to correct. Had to do that for two cameras and I think that is all I am going to do in my lifetime.
It's quite fun to be able to pick up nearly any old beaten to hell Spotmatic or Nikon F and it will either immediately work flawlessly, or only need the most minor repairs.
Yes. I bought my first Spotmatic for $20 with a 50mm f/1.4 Super Takumar. I cannot get the battery cover off to check the battery chamber or install a new battery, so the meter doesn’t work, but otherwise it works perfectly. A sticker inside indicates it was last serviced in 1989. It’s in good shape cosmetically too. I would get it serviced but I bought it to use for a “cheap shots challenge” photo contest where you have to use a camera that cost less than £20/$30 and the cost of service would take me over the limit.
My SL I purchased for $30 body only. On my first test roll, the rewind crank somehow came off. The camera otherwise continued working so I finished the roll, then threaded a nut onto the screw that the rewind crank attached to and rewound using a wrench. A quick trip to Eric Hendrickson had it repaired, CLAed, and working like new. It’s since become one of my favorite cameras.
I bought my K1000 from Goodwill auctions back when you could still occasionally find a good deal there. I couldn’t get the battery cover off this one either but I was able to remove the bottom plate and replace the battery from the other side. It has worked perfectly ever since.
I have yet to try a Nikon F or F2 but I want one of each. I have owned a Nikon FE for about 16 years and bought a second one more recently. I love the FE but I feel more confident in the reliability of my all mechanical Pentax cameras.
The only Spotmatic I've had an issue with (sticking mirror) was fixed by taking the bottom off and cleaning some grime off a few levers. Has worked flawlessly since. One looks like it's been dragged behind a bus and it's frighteningly reliable.
Highly recommend finding a nice plain prism Nikon F. I take one with me every day. The only recurring issues I've found are the mirror-up not working, and the slow speeds being gummed up (1/8 to 1 sec). Neither are really an issue in general use!
