michaelwj
Here is an interesting article... A couple quotes that supports my original position
"...adding additional elements, each designed to correct for specific aberrations, lens manufacturers can minimise their effects.
Adding additional elements isn’t a perfect fix. Every time light is transmitted from one lens to another a little bit of light is lost. The more elements in a lens, the more light and colour information that is lost in transmission. There is a trade off between correcting for optical aberrations and preserving information.
3D Rendition and Micro-Contrast
Older lenses have far fewer elements than modern lenses. These makes them more prone to optical aberrations and, in particular, it means they often have very soft edges. On the other hand, they can have some incredibly pleasing characteristics. Unlike resolution or sharpness, these characteristics are a lot more difficult to measure with a chart. "
Micro-contrast is the small amounts of tonal and colour variance between details on a subject. It’s an incredibly subtle effect but it is often what sets excellent glass—like Leica, Zeiss, Canon L series, medium-format or large-format lenses—apart from cheaper lenses. Micro-contrast is what gives areas of consistent colour a realistic and accurate texture. It is among the first detail to be lost when light passes through too many elements. "
Worth a read
Here Is What to Look For When You Buy Photography Lenses
https://photography.tutsplus.com/tu...or-when-you-buy-photography-lenses--cms-27047
The source you cite has no authority on these matters, and describes themselves as a photographer, adventurer, and man of mystery.
They are incorrect. The number of elements has nothing to do with “micro-contrast” or “3D pop”. I will say again, correlation does not equal causality.
The Zeiss Biogons and Distagons both have huge numbers of elements in heaps of groups, yet are often thrown in the “3D pop” and “micro contrast” heap.
