chuckroast
Just snagged a bucket list Nikkor, the 28mm f/2.8 AIS. Price was right so I couldn't pass it up. Gotta see what it looks like when it gets here.
Very few faster shooters than this set up.A sweet and very clean Leitz SLOOZ 28mm finder for my recently acquired lllg. Now that's the new carry everywhere camera.
Olympus XA with flash by Tim Murphy, on FlickrHello, this has been a common issue for the XA, Happened to my XA RF too, that one-stop off metering reading is due to separate metering circuits( one for viewfinder needle & controlling the shutter speed), CDS cell deteriorstion, battery issues, or meter movement issue due to dust and debris.Dear Board.
I took a chance on a Goodwill auction with no idea of the actual condition of the camera. It came with the manuals and nice zippered vinyl case that holds everything. Maybe I paid a lil' too much, but after loading fresh batteries in the camera and flash and playing with the controls, everything seems to work as intended. The shutter speed varies when I eye-ball it using different apertures, both with the film door open and on the meter reading scale in the viewfinder. The rangefinder patch is clear and bright and reads similar distances when focused compared to known good cameras. The flash powers up and fires. The only possible defect might be that the meter reads about 1 stop off to the low side. I have a roll of Arista 200 in it for a test drive.
Regards,
Tim Murphy
Harrisburg PA 🙂
Dear deadrangefinder76,Hello, this has been a common issue for the XA, Happened to my XA RF too, that one-stop off metering reading is due to separate metering circuits( one for viewfinder needle & controlling the shutter speed), CDS cell deteriorstion, battery issues, or meter movement issue due to dust and debris.
Good luck with your XA, hopefully it is not so bad,, maybe you can adjust ASA or send it to a pro.
Cheers!
Interesting adjustable stem -- maybe common in that era? What's that rear tire (OK, tyre)? Never seen a sewup like that.An unknown (probably) British track bicycle from the interwar period. Probably 1920s, loaded with nickel plated hardware mostly Brampton and BSA, and fitted with wood sprints.
Phil
It looks like nearly zero trail. A lot of bikes back then were like that. Should be interesting to see how it rides.An unknown (probably) British track bicycle from the interwar period. Probably 1920s, loaded with nickel plated hardware mostly Brampton and BSA, and fitted with wood sprints.
Phil
Armstrong?An unknown (probably) British track bicycle from the interwar period. Probably 1920s, loaded with nickel plated hardware mostly Brampton and BSA, and fitted with wood sprints.
Phil
By brother has a Bismarck bike from the 1950s. He restored it and he and my father used it for a long time. The last 20 years unfortunately is been left to rot in the garden.An unknown (probably) British track bicycle from the interwar period. Probably 1920s, loaded with nickel plated hardware mostly Brampton and BSA, and fitted with wood sprints.
Phil
CR Do you have a leicavit for your lllf ?Yep, but I'll put my IIIf w/21 f/4 Color-Skopar right up there with it for rapid shoot and scoot. That Skopar is stupidly sharp ... so much so I also use it on my Ms with an adapter ring.
NopeCR Do you have a leicavit for your lllf ?
Nope
"Yes, pets department, second floor."This sounds like a windup to a Monty Python inspired punchline.
