Nikkor 3.5cm 2.5 Lens Shade
Shotgun
10:59 AM
Boston NS
Hello, What is the proper lens shade for use on the LTM Nikkor 3.5cm, 2.5 lens? I am guessing the S-version is not correct? How to tell the difference?
Thanks, Shotgun
I think the square one to the left fits the 1.8
Extremely difficult to find, more expensive than the lens!
Kiu
I thought the regular shade for the 35/1.8 was expensive enough as they command over $200 usually, but never knew the square one ever existed? Have never seen it even in Bob’s books, or ever for sale.
The rectangular hood is for the LTM version of the W-Nikkor 35/1.8 only. The front of this lens doesn't rotate like its S-mount sibling, so there's no issues with the rectangular shape. Not surprising its not mentioned in Bob's books since Bob's focus is on S-mount. I've seen these hoods sell for upwards of US$1,000. Not quite as expensive as the lens they're intended for, but certainly getting up there and they're very hard to find too.
Thanks, Shotgun
The S-mount hood indeed isn't the correct hood for the LTM lens. The S-mount hood clips on to the S-mount lens's 43mm filter thread (or 48mm in the case of the later lens) whereas the LTM hood clips on to the LTM lens's 34.5mm filter thread.
For the W-Nikkor 3.5cm f/1.8 hoods are the models the AC-521 for the S-mount and the AC-519 for the LTM?
I've also seen AS-48 listed for the S-mount and ES-43 for the LTM. Appreciate help sorting it out.
Also, does the S-mount have two front lens caps - a 43mm clip-on and a 48mm slip-on?
